I'd like others to confirm, as I don't have a 2026 available to compare to my 2024
Research indicates, the 2026 Super Duty Platinum grille mounting and attachment points appear to be the same as 2023 - as they're both fifth-generation Super Duties.
I see on other aftermarket sites list the same grille assemblises as dired fit across model years 2023-2026.
Which usually means that:
- Upper grille bolt locations are unchanged
- Side clip geometry appears unchanged
- Hood latch support alignment is the same
- Headlight/grille interface is the same across 2023–2026
- Front camera and emblem mounting locations are generally retained
