Blown Motor
Holy smokes! Quite the carnage in there!
Got it back tonight.
Quite the paragraph on pg2.
Ford Customer care working on the extended warranty - offered 3y/36k (dealer had said 12mo/12k) which was a surprise - to the point that someone raised earlier that they don't talk, dealer tried to get me to swing by sales to "buy more"....
Thanks to all for the info and assistance!! Not sure there is a take away here other than "stuff happens".
Had a few recalls listed : they did 2 of what were 5 listed in FordPass.
View attachment 231198View attachment 231199View attachment 231200
Thanks for the follow-up. Glad you're back on the road and with new wiper arms to boot!
That was the first thing I thought of when I read this. Looks like they are taking care of you, but I also wish they took a new complete long block out of a box for you.
Given the circumstances of the failure, it appears the timing went out somehow??? So strange to have piston to valve contact that would literally bend rods. This is more than throwing a valve. It seems the whole engine went out of timing.. Did they ever give you root cause?
I had an old timer tell me if the crap hits the fan during warranty drive it straight to the dealer until it blows.
I only only blown one engine (not on this truck, but on a BMW) and it sucks. The insides wanted to be on the outside.
They're remanufactured blocks but regardless of the case, it still nice to know he didn't have to put his hand his pocket in order to get those wheel rolling again.
If you look at the error codes listed, P0341 refers to the camshaft position sensor, detecting that something is out of poistion.
I am willing to bet my last dollar that he spun his crank gear which is a topic we haven't touched much on but it is known issue with these engines and will become more of an issue especially with those of us (myself included), who enhance performance.
Ford decided that a pressed gear is enough to spin the the crank shaft and it works, until it doesn't.
Just goes to show you how weak that design can be, considering that this engine is totally stock (albeit pushing 475 ponies).
I've been contemplating on doing what most have done which is welding the gear to the crank.
If the objective is to insure positioning of the crank gear on crankshaft the best way to do so is to key way the crankshaft and the crank gear - at least that's the way we did it in bad old days running 427 side oilers and 454 bored and stroked big blocks running over 525 rwhp on 91 octane, more on racing gas where we could increase total advance.
Fully realize that times change and I have white hair 😁 welding of course is less intrusive than disassembly machine work required to key way the crank gear. A concern I'd have is improper TIG welding can weaken a crank gear due to the heat introduced, which can distort the part, reduce its hardness.
The internet being a dangerous thing, a quick search does indicate there are reputable firms offering crank gear welding prices and warranties like mileage vary, yet it seems $3500-$3800 seems to be the range.
Didn't they go back to a pinned/ woodruff key at some point?
Hopefully all of this nonsense is just a manufacturing one off.. I'm happy that the OP was treated properly by Ford, that at least gives me confidence that they stand behind their issues..
Unless there has been recent changes to the 6.7s, this design is standard on the 6.7 since the introduction of the engine back in 2011.
I do believe that the old 7.3L Powerstroke also had a pressed gear sprocket.
Ford then added a keyed crank gear to the 6.0L lineup and evidently felt it was not needed so that they can secure engine repair in their billing department when they released their new engine.
I've known about this being an issue with guys who run hot tunes and putting lots of stress on the engine when towing.
I don't hotrod my rig despite having custom tuning, and I don't usually tow heavy loads, but it's still something I plan to address eventually.
If I had access to a lift, I would have done it by now to save time, though it can be done with the cab on—it just requires pulling the entire front end out.
I've seen videos of people showing off their welding dimes by going around in quarter turns, but I think a spot weld is more than enough to keep that gear from spinning.
this, i've seen some really elaborate dimes stacked as well, I feel like you do, 2-3-4 spots to try and stay balanced and you would be good.
Confirmed it is shrink fit as of 2023. "A shrink fit installed front drive gear allows for direct drive
timing gears, improving NVH." This is from the 6.7 shop manual..
Same. It seems to be a rare event over the years of my surfing the forum.
Thanks all
No "root cause". And he sort of threw his hands up - "never seen it"
Thats funny - its NOT funny here, but its very true. It was quite a bang, but reading I'm somewhat amazed it wasnt a "BIGGER" bang.
That is as good of a guess as any I've heard and really seems to fit.
All in all - agree, I'm back in my truck, its fixed, and 0$ out of pocket, with some extra warranty coverage to boot. Whole thing has been frustrating, but they've really handled it well, so I'm pleased all things considered.
How much extra warranty did Ford allocate?
Does that mean 8/136 total?
