I have been wanting to start a thread about stuff like this... don't want to hijack here but... with my 2024 6.7L HO (stock with DCR) one thing I've been doing is when the DPF starts getting higher percentage and you can hear it in the exhaust like a ricer civic from fast and the furious haha... what I do is double tap the engine brake to Auto... putting in some added back pressure as somewhere suggested it can help a bit with blowing that snot out of the DPF to an extent until it starts the burn off...@JTredway
Obviously, what you see here is a 6.0L with a VGT that grenaded due to a bad EBP...
In reality I want that trash off the truck but in the meantime will that backpressure actually be bad or stupid to do?
- haven't hit first oil change yet
- DID replace both fuel filters/water separator already once (under 10500km just because)
- DID do the DCR conversion immediately after delivery
- Still under 12500km since April delivery
- Still using Archoil 6500 every fill even with DCR because why not?
- Drain/check water separator (2-4oz) once a month
My issue is the DCR and Ford... even if my dealer was willing to do the job and sees it as preventative like the DPK... Ford may have other thoughts to bypass warranty...
If stuff like this happens without warning and my driving is random from aggressive to grandpa depending on the moment... should I not use engine breaking so frequently? Anything else would be appreciated... likely will create a thread soon...
