usually not, usually its from inservice date or in this instance, inservice date of the new motor.Does that mean 8/136 total?
Waiting to see official paperwork - they said will be next week.Does that mean 8/136 total?
This is great sooner stock turbo takes a shit wife will authorize an upgradeI'll leave it to the true mechanics and engine experts to debate this, but I was told that running EBA (exhaust brake auto) constantly can cause increased wear on the turbo vanes over time (I'm assuming its the bearing themselves?). I am not sure on the extents of the effects of the diaper but one hypothetically argue since its blocking flow of the exhaust and reintroducing it back to the engine, it prevents it from filling up quicker?
Light-duty diesels don't have engine brakes like heavy-duty diesels, which are valve-operated. Instead, our turbos use vanes to generate back pressure to starve the engine of air.
Even heavy-duty diesels require regular calibration of their engine brakes (the exhaust valves themselves) to maintain optimal performance. Any moving part that experiences frequent operation, will wear and may eventually need replacement or calibration (maintenance).
The VGT turbos are designed to control the position of the vanes based on RPMs, balancing spool and back pressure to prevent failures like the example mentioned. I’m not sure of the exact percentage, but failures are less frequent on the 6.7s, if at all (caused more from sticky vanes due to carbon buildup). However, keep in mind that the vanes, which abruptly close every time the EB is activated and senses a release of engine load, will experience much more wear over time.
Backpressure can also creates more heat in the engine, which is more concerning in my opinion, during full spool (an example would be producing more power but restricted exhaust either by diameter or emissions).
Ever get clarification on how much extra warranty ford will offer?Waiting to see official paperwork - they said will be next week.
I got 7year/100K mile extended warranty after my motor imploded. Had to hound the shit out of Ford and ultimately file a BBB claim. That made them do it finally.Ever get clarification on how much extra warranty ford will offer?
Have you considered welding the gear to the crank?I got 7year/100K mile extended warranty after my motor imploded. Had to hound the shit out of Ford and ultimately file a BBB claim. That made them do it finally.
say what?Have you considered welding the gear to the crank?
Yup. Wanted to do mine at dcr time didn't realize it was so labor intensive till shop told meYour warranty response made me think you were the original poster about the blown engine.
I don’t think a thorough diagnosis was given, but it sounds like he spun the crank gear on the shaft.
This is one of the biggest weak points on the 6.7s, though it’s rarely mentioned. The crank gear is pressed onto the shaft rather than keyed. I’ve thought about doing this to mine, but it requires pulling the front grille off; its quite the job to get to the crank shaft.
Before dropping the engine in, it would have been the perfect time to pull the front cover off to get some TIG welds added to that gear.
I dont think it's super common with stock to moderate power and I think some of it just truly depends on how hard you a beating on the truck but there have been stock trucks fail. Again though not super common and honestly, I think it's a function potentially of load and driving style. Like if you are hard on the throttle and let out and hard decel against the engine brake. Guys running up against the limiters and what not.Mine would do it... but pressured me to look at my future plans first, and would consider options down the road after the DCR job. Said there's lot of things that can be done but, don't need to jump the gun unless I'm considering high horsepower applications like a race truck.
100%I think some of it just truly depends on how hard you a beating on the truck.
absolutely and quite possible. It's all a crapshoot ya know. Spun crank could be from any number of things, the latest is blaming the DCR for spinning it due to different harmonics/gear lash from what I am seeing on a lot of the groups, some going as far to argue that while you can't spin the CP4 by hand, it's pressure remains constant and that a DCR while you can spin with hte hand, pressure increases with RPM and demand. Don't see how that would be any different than a cp4 but who knows lol. If i was going for big power and pulling the motor apart for some other deep dive work, it would 100% be a since you was there kinda deal.Beast2021 might be the 1 in a 1,000 that spun his with a stock set up.
Now there's this to worry about. Just never sp-endingabsolutely and quite possible. It's all a crapshoot ya know. Spun crank could be from any number of things, the latest is blaming the DCR for spinning it due to different harmonics/gear lash from what I am seeing on a lot of the groups, some going as far to argue that while you can't spin the CP4 by hand, it's pressure remains constant and that a DCR while you can spin with hte hand, pressure increases with RPM and demand. Don't see how that would be any different than a cp4 but who knows lol. If i was going for big power and pulling the motor apart for some other deep dive work, it would 100% be a since you was there kinda deal.
I want compounds next lolNow there's this to worry about. Just never sp-ending![]()
