Best stubby antenna?
I chose not to run a stubby and went with TheCatsPajamas that sits just slightly above the highest point of the cab. It looks almost identical to the factory antenna and maintains comparable performance. It extends about one inch above the rear GPS and XM antenna housing, which is the highest point on my truck.
The main driver for this change was my parking garage, which has 7-foot clearance. The stock antenna hit nearly every concrete support beam. With the shorter antenna, I now only make contact in two isolated spots. In those areas, I have approximately 1/2 inch of clearance.
This gives the truck a much cleaner profile while preserving reception and improving usability in low clearance environments - leaving my "early crush detection" in place. I still listen to AM radio, so I wanted something that provided as good of signal as possible.
The only downside for me is needing to pull it off before running through a car wash, which I do despite their claims it will survive frequent car washes.
Thanks again for the recommendation! Looks VERY similar to OEM but about 3 inches shorter. Purchased and installed!
You mean Lauren Sanchez lip and b00b fund.
I typed out something along those lines and stopped myself from hitting post 😂😂😂
"Every time you buy something on Amazon, Jeff's wife gets another lip injection."
My conscience has a hard time keeping up with my mouth and keyboard 😁
  • Winner
Reactions: McE
I bought this one
I've had it since November but not one time have I tried the radio to see if it works or not. :ROFLMAO::ROFLMAO:
Ronin SmartLock Antenna 12". Radio still works well, but I only listen to one radio station, 95.5 KLOS
I might be one of the only folks that likes the OE for the fact that it hits first in tight places, but this one might change my mind.
I like hitting first in tight places too!
Good reception, flexible, freely spins and locked in place! Went with this SMARTLOCK™ SHORT FLEXIBLE ANTENNA 5 INCH:
just bought a new house with a door that clears the truck by about 2” but the antenna drags across the header and garage door. Can anyone recommend a shorter antenna that won’t lose tons of reception?
I picked up a stubby billet about 4" from Autozone. About $30. Works great.
Stubby antennas have been discussed on several threads, and I believe the conclusion was that there isn't a real noticeable difference in any of them.
Can you just snip the tip of your factory antenna?
I don’t know for sure, but I believe you can snip a little without killing reception quality.
I snipped mine a long time ago and it didn't kill the reception quality! 🤪
