I chose not to run a stubby and went with
TheCatsPajamas that sits just slightly above the highest point of the cab. It looks almost identical to the factory antenna and maintains comparable performance. It extends about one inch above the rear GPS and XM antenna housing, which is the highest point on my truck.
The main driver for this change was my parking garage, which has 7-foot clearance. The stock antenna hit nearly every concrete support beam. With the shorter antenna, I now only make contact in two isolated spots. In those areas, I have approximately 1/2 inch of clearance.
This gives the truck a much cleaner profile while preserving reception and improving usability in low clearance environments - leaving my "early crush detection" in place. I still listen to AM radio, so I wanted something that provided as good of signal as possible.
The only downside for me is needing to pull it off before running through a car wash, which I do despite their claims it will survive frequent car washes.
