Batteries leaking
Confirming Alpoba's confirmation. My '23 came with a pair of AGMs. Worried about terrible Motorcraft batteries, I went out to inspect and charge my '21 F-150 (bought new in early '22) and discovered it had an AGM battery in it as well.
I guess the costs of replacing all those worthless batteries under warranty over and over shifted the cost/benefit enough to convince Ford to start putting in better ones. 😏
I've heard the 150's came standard with AGM for awhile, or as long as auto start stop has been in use. In the Super Duty it's been long overdue, although I hear that the single battery gas trucks still get the flooded battery.
Yep, F-150’s going to AGM originally was almost certainly driven by auto stop/start. You’ll find AGM’s in any vehicle with that feature because of how hard all those extra starts are on the battery, and the ability to do more starts before losing voltage.
No idea why they finally moved the Super Duty. Obviously not auto stop/start since that’s not a thing for Super Duty. Best guess would be the added durability and the failure rate.
I'd forgotten that stop/start "feature" existed. My truck came with it deleted and a $50 credit to not have that annoyance. Could have been a deal killer if it was on there and not possible to disable.
Just had both of them replaced again yesterday... I have lost count at this point. I'm either at 6 new or 8 new. I'm at 13 months and 24,000 miles. I'm sure they'll be replaced at least once if not twice more before the 3/36. Then, when those are shot I'll get some decent AGMs.
Surely after that many it would be worth it to buy your own AGMs just due to the wasted time at the dealer. Anything I ever do there is minimum 48 hours with no truck even with an “appointment”.
Thanks to this great forum, I checked my batteries. The top of the driver side battery was wet with corrosion on the battery hold down and the negative post.
I installed new AGM batteries and replaced the hold down. Hopefully good for awhile!
Thank you for all the great information that is shared
I have been able to find decent dealers with respectable service departments. Always back the same day, usually in a couple hours, and I take care of warranty stuff during regular service appointments like oil changes. Plus, at this point I'm just being obstinate about it (Same goes with the shocks which are getting replaced again). The time commitment isn't a problem for me as I can work from virtually anywhere.
As long as something is covered, they're going to keep having to replace it.
There's an end to everything for most. Apparently not for you! Bless you! The exponential improvement I experienced from aftermarket shocks, and not having to worry about leaking batteries has made my ownership experience so much better. Screw Ford, screw the dealer, your persistence means nothing to them.
Hey Guys, I was coming on here for the same issue... I think. A few weeks ago the truck wouldnt start. Just heard 2 clicks and then nothing. Lights still worked. Popped the hood. Lots of corrosion on positive battery terminal (way more on driver side battery) which I had seen lots of times before when I clean the engine bay but this time was ridiculous amount so I spent an hour making that terminal shine. Then I went to AutoZone and bought a new battery. Only 1 battery because the volt meter seemed fine on the passenger side. Truck worked fine. This morning same thing. Click and no start. And then after a few times not even a click. Had to get to work so took the wifes car but I now realize the replacement battery is not an AGM. So do I need 2 new AGM batteries? or can it be something else? Any help would be appreciated. The Ford service by me sucks.
You always replace both batteries even if one is showing good. Yes, 2 high quality AGM would be my recommendation 😀
Something similar happened to me symptom wise. I ended up replacing one of the batteries with another flooded battery. Then about 5 months later same thing. I just ended up putting two Odyssey AGM batteries and starts up every time better than before. A little expensive but 4 year warranty. Not sure this helps you too much but maybe.
Batteries plus + offers these, 5 year warranty! A bit less than the Odyssey, i have heard they share the same manufacturer, but unconfirmed!
I wanted to get these but my Batteries+ said they were on back order so ended up with Odyssey from a local shop. Also, heard these are good plus the warranty had caught my eye!
I am on my 3rd set of factory leakers. As long as Ford keep swapping them under warranty I'll keep using them. If they leave me stranded even once they will be replaced with a set of the X2 AGM's
I've had my batteries replaced twice under warranty now for the same thing. Also made them replace the hold down bracket and associated hardware once because it was corroding. Once warranty is up ill replace them with something better.
I would surmise from the sequence of events you described that the new battery was drained trying to keep the other (old) battery charged. If the new battery was drained enough, you may not have enough current left to start the truck, the reason you have two batteries on a diesel. (Assuming you have a diesel.) This is one of the main reasons you always replace both batteries at the same time, they should age equally and will change over time.
Aside from that, if you have a drain somewhere else, the batteries may still drain. If this happens with two new batteries, you may have to look into troubleshooting a parasitic draw. Not fun for the inexperienced.
When my original batteries leaked, it also corroded the hold down bracket. I replaced both batteries with sealed AGMs and replaced the brackets. I also put several coats of clearcoat on the new brackets, just in case... 🤞
I got my flooded batteries replaced under warranty the other day. ...again. It's worth noting that Ford will not warranty them unless they test bad. Mine were both wet and both tie downs were corroded and rusted but they told me they couldn't be covered unless they were bad.
The service manager I was working with realized it was a load of shit and tested a known bad battery so he could replace mine. Once this pair start leaking, I'm switching to AGMs.
Figured I'd pass it along for anyone trying to get theirs replaced.
Yeah its a diesel. I am headed home to swap them both out and report back. Never had this issue in my 2017 F250 or my 2019 Raptor.
