Batteries leaking
There’s an AGM option in Forscan.
Forgive my ignorance @BroncoHooves, but I am curious why the type of battery needs to be changed in forscan rather than just swapping out batteries? Thank you man for your expertise!
Charge profile is different than the OEM flooded leakers.
The forescan change needs to be done at the time the new AGM's go in, or can it wait till after?
Simply install the AGMs, then change the Forscan profile from flooded to AGM as Broncohooves stated as the charge profile is different. I also dropped the recharge percentage from the factory set 120 down to 105. This was simply an educated guess as to what number to choose. In all of my research I haven’t found a consensus on what percent it should be. 105 seemed to be reported the most often. I have had zero issues since install and reprogramming.
Does it need to be done right away, or can it wait a day or two, thank you in advance.
I am honestly not qualified to give a reliable response. Many, several on here even, have installed the AGMs and not changed anything in Forscan. Didn’t change the “flooded to agm“ and did’t drop the “recharge percentages” and haven’t reported any problems. So…..not sure what that implies. I would think since there are two settings for each battery type in Forscan there is indeed a difference in how the two function and therefore should be changed. How soon does it need to be done, I do not know. As far as the percentage for recharge goes, I just went with the most common number I could find. Obviously AGMs don’t need 120% but what should it be? I don’t know. Sorry, not much help.
Percentage change (SOC) did nothing for me at all when testing.
It wouldn't be the first Forscan setting that didn't do anything :D
The charge profile of AGM is different than SLA in that it can handle higher charge voltages. Target SOC is only as good as the BMS's knowledge of the true SOC. It looked like Ford did a good job ensuring all wires connected to the negative battery terminal go through the CT, so I had a hard time believing >100% should be used as it would only result in overcharging, which is bad for battery life. Of course this is all a gross assumption in how Ford actually programmed the truck!
Well add me to the leaking battery club. Went under the hood and saw a lot of corrosion on the hold down bracket of the driver's side battery. Off to Ford service next week. I'd love to swap them for the X2 AGM's but I have pother projects ahead of that to I'll have live with the stockers for now.
If the battery still tests good there is a chance they will just clean it up and send you on your way.
Well good news Ford Service replaced the leaking battery and did a BMS reset no questions asked. My service advisor said this was the first she has heard about leaking batteries but that did not stop them from doing the work and getting me out the door quickly.
I only found the issue when I went to scope out a mounting position for the ARB dual compressor. I didn't want to mount it until Ford replaced the battery in case they tried to blame me for damaging it when I installed the bracket. At least I now have a fun project for the long Thanksgiving weekend!
Just had both of them replaced again yesterday... I have lost count at this point. I'm either at 6 new or 8 new. I'm at 13 months and 24,000 miles. I'm sure they'll be replaced at least once if not twice more before the 3/36. Then, when those are shot I'll get some decent AGMs.
I keep hearing Ford went AGM route starting with 23s. Wonder if anyone can confirm with certainty, that would be a good thing.
I don't see that anyone ever answered this - does anyone know?
I was a bit surprised when I first started reading about this - I don't think I've owned anything with a flooded battery since the '80's.
Yes, i can confirm myself now. Came with my 23 from the factory. Both 7.3 and 6.7 now come with AGMs.
Confirming Alpoba's confirmation. My '23 came with a pair of AGMs. Worried about terrible Motorcraft batteries, I went out to inspect and charge my '21 F-150 (bought new in early '22) and discovered it had an AGM battery in it as well.
I guess the costs of replacing all those worthless batteries under warranty over and over shifted the cost/benefit enough to convince Ford to start putting in better ones. 😏
My 2023 Tremor King Ranch has the AGM batteries as well.
