So, I've been having this weird issue with my truck lately. After it sits for 4 or more days, I'd try to remote start it, only for it to turn over for a split second, shut off, and then start blaring the alarm! It's like it forgot it was commanded to start. Oddly enough, if I unlocked the doors and hit the start button myself, everything would be fine. Battery voltage was reading 12.4v before starting (smart shunt logs both truck and solar battery banks voltages) and 10v during start, so I was scratching my head a bit.
Finally decided to replace the batteries. Was eyeing the X2, but ended up going with the XS Power D6500 12 Volt AGM. After a 4-hour install, the difference is night and day. The truck starts way quicker now, and even the mirrors fold in and out faster. Best of all? No more identity crisis alarms after sitting!
During the replacement I noticed the driver's side battery had been leaking and started to corrode the tie-down. Also, turns out "Group size 65" is more of a suggestion than a hard rule. Either Ford's been skimping on some lead to save a few bucks, or XS is pushing the limits to squeeze out more cranking amps. Either way, I ended up with about a quarter of the new battery not quite fitting in the tray.
A little work with a torch here and a rotary file there, and I've now got two properly secured batteries that start the truck like a charm.
Quick question for you AGM swappers out there - did you install without that little insulation shield to make sure the battery fit before putting the insulation back? The only reason I caught the fit issue was because I was struggling with the insulation and took it off, only to find the battery wasn't sitting right in its slot.
