7.3 Godzilla Engine Noise
Just did my third oil change this weekend at 15K miles. Decided to cut my oil filter open to make sure there was no forbidden glitter in the filter media. Filter was good to go, I also took an oil sample while it was draining and sent it to Blackstone Labs. It’ll probably be a few weeks before I get the results back. Good news is at least in my particular truck the noise doesn’t seem to be producing any metal in the oil 🤞. I’ll post the results up when they come in.
Sorry to bring up an old thread but I know a lot of folks were following this. Ford just released a TSB on what I think is this issue. You can look it up for yourself but goes on to say if the camshaft and valve tappets look good, to pull the oil filter and check it for metal. And replace the engine.
I really think it is a different issue than that TSB. It comes and goes. Mine has been gone for a thousand miles now. A worn cam or valve would continue to the make the noise once compromised.
Sorry to bring up an old thread but I know a lot of folks were following this. Ford just released a TSB on what I think is this issue. You can look it up for yourself but goes on to say if the camshaft and valve tappets look good, to pull the oil filter and check it for metal. And replace the engine. View attachment 213713
Do you have the TSB# ?
Mine actually just came back after I took my camper on an hour away trip. The difference this time though if I hold my brake, it goes away some of the time. And it's lasted a little longer. By that I mean when it first started it would go away within the day now it's been 3 days of me cranking it up and driving to the store and back and it's yet to go away. I'm at 16600ish miles now and I have one more trip 4th of July week. If it happens again then I'm taking it to the damn dealer this time 🤣🤣🤣
My 23 warranty runs out next spring. I have no choice but to purchase the extended warranty.
25-2200 maybe? Idk, feel free to look it up…View attachment 213757
TSB Attached. The important part for us is the following repair procedure on pg7 starting with the familiar spark plug/wire assessment until the first point of failure is determined:
2020-2025 F-Super Duty: Retrieve DTCs, Inspect Ignition Coil Wires And Spark Plugs For Damage (Fail) Complete Repair Outside Of This Article
2020-2025 F-Super Duty: Retrieve DTCs, Inspect Ignition Coil Wires And Spark Plugs For Damage (Pass) Using Scan Tool Cancel Cylinders, Remove And Inspect Oil Filter (Fail) Replace Engine Long Block (Do Not Use With Any Other Labor Operations Outside Of This Article)
2020-2025 F-Super Duty: Retrieve DTCs, Inspect Ignition Coil Wires And Spark Plugs For Damage (Pass) Using Scan Tool Cancel Cylinders, Remove And Inspect Oil Filter (Pass) Remove Cylinder Heads And Inspect Camshaft And Tappets And Engine Block Cylinder Walls Replace Camshsft And all Valve Tappets (Do Not Use With Any Other Labor Operations Outside Of This Article)
2020-2025 F-Super Duty: Retrieve DTCs, Inspect Ignition Coil Wires And Spark Plugs For Damage (Pass) Using Scan Tool Cancel Cylinders, Remove And Inspect Oil Filter (Pass) Remove Cylinder Heads And Inspect Camshaft And Tappets And Engine Block Cylinder Walls Replace Engine Long Block (Do Not Use With Any Other Labor Operations Outside Of This Article)
2020-2025 F-Super Duty: Additional Time To Perform 360 Degree Camera Alignment If Equipped (Can Be Claimed With Operations F, G And H)
Wanted to jump in on this to help the community as many posts on this site have helped me. The videos above are all showing vehicles with a blown catalytic converter. Mine broke apart internally at just 5000 miles after a long tow and made exactly the same sounds. It can be worse or more obvious on a slight incline because the entire matrix or loose chunks become dislogged and rattle around in the housing. Hope this helps someone.
I'd respectfully disagree. The sound mentioned through this thread was always coming and going before my motor was replaced. With this new engine, I've never heard it....not once.
Is is possible with towing excess heat causes something to expand or a tolerance to tighten up. Thinking torque converter or flywheel bolt contacting a inspection cover or transmission or block webbing? After it contacts for a while one of the culprits is eroded away. Could anyone with this noise remove the inspection plate and run a inspection camera up in that area to look for shiny metal contact points or flaking?
This theory makes more sense but it goes away fast. Way before you can get in to see the dealer. It happens 90% of time after towing heavy. Fine towing the same day. Leave it over night and it makes this sound. Drive it around a little and it sounds bad, then goes away completely. The dealer will just keep it for a week and say they can't replicate it.
Mine made the noise again today for ~20 seconds after an afternoon cold start leaving work. Towed the boat this past weekend, maybe 6,000#. Drove 8 minutes to work this morning, parked for 12 hours, cranked it up to leave tonight and started chirping away. 16,000 miles. 🤷‍♂️
so it went away after 20 seconds of idling or you drove it and went away?
Stopped after 20 seconds of idling. It does it randomly with no rhyme or reason. At this point I’ll probably just trade the truck when the powertrain warranty is up. I’ll probably want something different in 4 more years anyways.
