I had the same similar thing happen when one of my cats went out on a different vehicle. These trucks are known for having issues with the catalytic converters. Alternative, long tube headers and delete the cats or install sport cats.
Maybe the bolts slowly unscrewing themselves? Clackety, erosion, quits, bold backs out more, repeat? This would keep me up at night until I could pull the inspection plate off and stick a camera up there. I think I saw a post on this forum about flywheel or bellhousing bolts backing out?This theory makes more sense but it goes away fast. Way before you can get in to see the dealer. It happens 90% of time after towing heavy. Fine towing the same day. Leave it over night and it makes this sound. Drive it around a little and it sounds bad, then goes away completely. The dealer will just keep it for a week and say they can't replicate it.
Mine did it for three days after the tow before last. Then, last tow, it did it once in the morning during our camping trip for about five minutes. Towed back home and hasn't made it since.... Always go to the same place and take the same route, so....Towed my 7000lb travel trailer this weekend. Inaugural shakedown so just towed to a spot 20 miles away. Left the next morning and truck started making the noise again but it stopped after about 10 mins. I need to bring my mechanic’s stethoscope on the next trip and crawl under and pinpoint exactly where it is coming from. My money is on the cats based on the tinny and tinkish noises.
Thanks for posting this. It's good to have some official documentation whenever I get to the dealer. I'm very surprised they actually wrote that part down about modifying the parts!Been trying to get the video of my truck making the same noise as OP's since I got it back from the dealership but have been unsuccessful so I am glad to have found this thread to add to the conversation.
Only made the noise when retrieving boat at ramp. Didn't do it when launching the boat or any other time for that matter. Started August 2024. Late 2024 service department visit resulted in no action as they could not replicate the noise. Returned to service department April 2025 after four consecutive instances of noise making while retrieving boat. Dealership still could not replicate. After two months I finally badgered owner and GM into getting Ford involved. Field Service Engineer had them try different things (cut open oil filter then remove starter/inspect things) only to ultimately approve replacing torque converter and an associated bracket. Service invoice attached as well. Over $3,500 in parts and no telling how much labor to replace with the same parts that failed. (Converter and bracket part numbers come up for 20-22 models only.) Truck in shop for over 12 weeks. Can't say I am particularly happy with the "alternative engineering" listed on the invoice but maybe it will "cure" the problem. Just hope I am not in for this again. Luckily I have a 7 year service contract in place.
Probably too early to ask but, has it come back? Mine just did it this morning and I haven't towed since July 4th weekend...Been trying to get the video of my truck making the same noise as OP's since I got it back from the dealership but have been unsuccessful so I am glad to have found this thread to add to the conversation.
Probably too early to ask but, has it come back? ....
Mine was similar to Blade420. But mine was noticeable only around 2200-2800. At first only with colder temps. Then it became more and more frequent with warmer temps. Always around 2200-2800rpm. More common id say on incline or towing. But Honestly seemed like an exhaust or manifold leak. Well last week I got a misfire code and decided to get to the dealer. Lifter failure at 91,000. And slated for a new motor. Allegedly dealer said this is very common for high idle service trucks and Amazon trucks that run the 7.3 Godzilla. Not my situation. And… Unfortunately mine not under warranty so out of pocket for me.It seems like there are a few different clicking or tapping sounds. Mine sounded nothing like the video just posted by @Bluezilla. Sounded pretty much exactly like the video early in this thread by @Blade420Play🔪 . More of a cyclical tapping sound, like the Spoonman was under my truck tapping out a rhythm. RIP Chris Cornell.
