7.3 Godzilla Engine Noise
I probed around for about 30 minutes with an automotive stethoscope, under and around the top of the engine. Nothing noticeable coming from the exhaust, heat shielding, oil pan. The most suspicious spot that I checked was the fuel rail, I'm not really sure what to make of it. I don't know my way around engines that well, so not really sure all of the things I was probing. The noise has been happening fairly consistently since I first noticed it Sunday, but does go away completely from time to time. I'm leaning towards it being the lifter delamination issues. I don't drive my truck all that much, only 15k miles on it after about 3.5 years, so under warranty for the next year and a half. Will see what the local service department says, but I'm not super optimistic.
So mine started making the same sound day after I pulled my cargo trailer maybe 2700lbs. Two mornings in a row after cold start. It does go away after a little bit. Mine is a 24 Tremor with 10K miles.
Same exact sound as mine. I shot a video of it this past weekend on a drive the morning after I pulled my RV. The noise sounds like it is coming from bellhousing, cat/heat shield or starter. Sounds more like on the passenger side. A few weeks ago I checked my exhaust manifold heat shields and I had one bolt on the passenger side that allowed me to torque it a quarter turn. Noise was quieter last weekend (vs weekend before after tow) after I did this. Don't know if this was a coincidence or not. Hopefully someone will have this successfully diagnosed soon as a minor problem.
I also forgot to mention, I pulled my dust plate off my bellhousing to inspect torque converter bolts and there was no visible wear on bolt heads as if they had been rubbing anything.
I would think if it was the torque converter it would be constant. Mine stops after a short drive. Almost like after it warmed up, it stops. When I get back home I’m going to try and use a stethoscope and try and get a better idea of where it’s coming from. May just bring it in to the dealer and see what they have to say.
It will never make that noise for them. If I even think of taking mine in, it friggin stops as I am formulating the idea.
TSB Attached. The important part for us is the following repair procedure on pg7 starting with the familiar spark plug/wire assessment until the first point of failure is determined:
2020-2025 F-Super Duty: Retrieve DTCs, Inspect Ignition Coil Wires And Spark Plugs For Damage (Fail) Complete Repair Outside Of This Article
2020-2025 F-Super Duty: Retrieve DTCs, Inspect Ignition Coil Wires And Spark Plugs For Damage (Pass) Using Scan Tool Cancel Cylinders, Remove And Inspect Oil Filter (Fail) Replace Engine Long Block (Do Not Use With Any Other Labor Operations Outside Of This Article)
2020-2025 F-Super Duty: Retrieve DTCs, Inspect Ignition Coil Wires And Spark Plugs For Damage (Pass) Using Scan Tool Cancel Cylinders, Remove And Inspect Oil Filter (Pass) Remove Cylinder Heads And Inspect Camshaft And Tappets And Engine Block Cylinder Walls Replace Camshsft And all Valve Tappets (Do Not Use With Any Other Labor Operations Outside Of This Article)
2020-2025 F-Super Duty: Retrieve DTCs, Inspect Ignition Coil Wires And Spark Plugs For Damage (Pass) Using Scan Tool Cancel Cylinders, Remove And Inspect Oil Filter (Pass) Remove Cylinder Heads And Inspect Camshaft And Tappets And Engine Block Cylinder Walls Replace Engine Long Block (Do Not Use With Any Other Labor Operations Outside Of This Article)
2020-2025 F-Super Duty: Additional Time To Perform 360 Degree Camera Alignment If Equipped (Can Be Claimed With Operations F, G And H)
Thank you
This is super helpful 👍
Saw this on a different Ford forum…this SSM just dropped Friday. My truck makes the noise nearly every day now. 19,200 miles on it at the moment. I’m going to make an appointment at the dealer soon to have this SSM addressed as well as make sure the low idle PSI software flash has been done.
Thank you so much for sharing.
Well well well, looks like Ford finally answered what the rattling noise is from the bell housing area.
My luck, they come up with a "spacer plate" resolution after the "alternative engineering" (file down contact area) "solution" on mine.
I wonder if the spacer plate corrects the underlying problem or merely eliminates the manifestation of it (as I suspect the file-down "cure" did).
It's good to finally see something from Ford. I'm out on a monthlong trip towing our RV. It's been 2500 miles of towing so far and I thought the noise finally went away. But no such luck as of this morning. I have noticed that once the tranny temp gets up above 200 then it will stop. I'll take it in when I get home next week. Luckily the dealer is close so the transmission temp won't get high enough to cause it to stop.
My truck had this exact noise from the first time I towed with it. Only happened after I towed and started the truck the next morning. Took it to the dealer ended up with a new motor after they found metal in the oil filter 2023 tremor with 15k on it. I still don’t think the noise was the motor. Just a coincidence maybe that the cam was delaminating and I had this noise in the bell housing area. Truck also had a bad rear axle that had to be completely rebuilt. Axle went bad before 10k. Really thinking trading it for a diesel.
Does anyone have a part number for the "Engine to Transmission Spacer Plate" referenced in SSM 54269 attached in post #109. (FWIW, SSM 54269 appears to have been superseded by SSM 54363. Not sure what the modification was as I only saw it briefly during an on-line Microsoft Teams meeting with my dealership's GM.)
Ford has told my dealership they will pay for a transmission removal to determine if a spacer plate was installed during the repair to my transmission (post #87). No part number for a spacer plate is on the invoice so it would have had to be an existing part. Trying to figure out if this is a new part (and when it was issued) to determine if I want to go through it all again.
Can you share more about what you did/found? I made the original post a while back and am sitting at a campsite just ticking away when I crank up. Again I had to back down and include with the camper. Same situation as every other time. I’m at 40k now and still under warranty.
Thanks to everyone for continuing to look into this.
Get these dudes out of your transmission. The steel drum recall.
I took mine into the dealer to have that towing recall done and asked them to look at this. Of course my truck isn't making the noise at this time so I got the could not replicate diagnosis. Heading out on a 6000 mile towing trip in about a month so I'm sure it will start back then.
Any additional or new information on this???? Mine has done this off and on, I mean it does it sometimes but never when I take it in........
