All of you with the 7.3 get a tuner it’s the solve. When it’s programmed to shift through every gear it works flawlessly. You can get a transmission tune only if you don’t want to add power via oe air/fuel settings
I wonder if there's a failure due to the first failure and they didn't prep right. ie flushing lines and replacing trans coolers
Hey Betty, you have link for the tuner?
Custom Tunes & Performance Tuners - 5 Star Tuning
Unleash peak performance with 5-Star Tuning! Custom tunes for F150s, Raptors, Mustangs, Motorhomes, Trucks & More. Shop tuners now!5startuning.com
Shoot! Another option that a friend of mine said worked on his is the AFE transmission pan upgrade. I believe it holds 2 quarts more oil and he said that fixed his hard shift problem without tune.
Interesting for sure, because the oil cooler on the 6.7L, per workshop manual, is supposed to be replaced if any damage occurs. Even if no debris comes out, there could still be some within it that would dislodge itself over time.I wonder if there's a failure due to the first failure and they didn't prep right. ie flushing lines and replacing trans coolers
Most aftermarket trans builders require documentation of this and mandatory replacement of the trans cooler for warranty. I only know this from trans shopping when I had my 6.0 powerstroke.Interesting for sure, because the oil cooler on the 6.7L, per workshop manual, is supposed to be replaced if any damage occurs. Even if no debris comes out, there could still be some within it that would dislodge itself over time.
The same would apply to the transmission cooler.
extended warranty i hopeWelp, getting massive shift problems in 5th gear now (lags, hard shifts into gear, etc). Down shifting into 3 is becoming a pain as well. Feels like 3rd gear grabs and I get thrown through the windshield. I'll be taking it into the dealer next month before a trip. 56k on last production line '22, 7.3
