IMO, the 10R140 is the 'weak link' in the Super Duty drivetrain. Suncoast offers three different versions of the Ford 10R140 with notable improvements to the OEM unit. At this time, all three categories of the Suncoast Ford 10R140 have torque converters with the lower RPM stall speeds for the 6.7L Powerstroke diesel. I have not researched if there are any aftermarket performance torque converters with higher RPM stall speeds designed to be used behind the 7.3L godzilla. For 6.7L truck owners, Suncoast would be a better choice than OEM if the truck is out of warranty.
Suncoast has a well written write up of the OEM deficiencies found in the OEM 10R140. Specifically, they refer to the E Clutch Pack and the F Clutch Pack as
'evil twin redheaded stepchildren'. Furthermore, Suncoast states:
1.
The E clutch in a 10R140 transmission, is engaged in 1,3,5,6,7,8, and 9th. The real issue becomes apparent pretty quick. This clutch is cycled on 3 times and off 2 times by the time you are in 5th gear. The clutch is on in 1st then cycled off in 2nd, cycled back on in 3rd, then back off in 4th...only to be cycled back on in 5th gear. In higher-horsepower or higher-demand towing and hauling situations, this constant cycling on and off can lead to premature failure.
2.
The F clutch is also prone to premature wear as we have seen with other Lepelletier Ravigneaux Gear sets...oncoming clutches in higher gears seems to take the blunt of the beating. With the new 10R140 transmission, the F clutch is no exception. The F clutch is engaged in R,4,5,6,7,8 and 9th. The quickest path to early or premature degradation to this clutch pack is wide open throttle or heavy-load-indexed 3rd to 4th shifts. This is especially prominent in applications where torque management has been deleted.
EDIT: Talked to Ernie at Suncoast and he stated they can build a Ford 10R140 for the 7.3L godzilla application.
SunCoast Performance SC-10R140-CAT3D Category 3 10R140 Transmission with Expanded Capacity is engineered for Ford F-250, F-350, F-450, and F-550 trucks. Featuring Raybestos GPZ clutches, expanded capacity E & F clutch modules, Pro Loc valve body, Sonnax regulator upgrades, and advanced...
suncoastdiesel.com
