I'll give an update on my 2020, it is an F350 4x4 CC SRW 8' Box 7.3L, 3.73 gear, November of 2019 build date, I took delivery of it in April of 2020. Truck had 5 miles on it at time of delivery.
Truck was great until around 15,000 miles when I noticed a slight vibration coming from the rear, mentioned this to the service department at my regular 5k oil change, at the time they didn't want to do the tire rotation but I insisted (would notice a change of vibration if it would move to the front). No change after tire rotation vibration still from the rear. Mentioned the vibration had slightly increased at 20k oil change, at 22k I noticed a leak from the pinion seal, notified dealer and made appointment, at 25k it finally went in for repair, ring and pinion gear failure. That was in May of 2021, do to shortages of parts, wrong or damaged parts sent, it took 3 months to complete the repair.
In December of 2021 I noticed hard shifts, hard engagement from park to drive or reverse, skip shifts and at times holding the gear (no upshift). Contacted dealer to set appointment, then it finally threw a code P07F7, truck became undrivable, at times it would have "dead pedal" after coming to a stop. This got worse with warmer tranny temps. Truck goes in for repair tail end of December 2020 with 34k on the clock. Vehicle is at the dealer for a month. they replaced CDF Clutch Cylinder per TSB-21-2323.
Get the truck back and after 3.5 miles I again get a hard shift. Contact dealer and after setting another appointment and waiting to get in the truck has been there since Wednesday for a valve body replacement.
I traded in my 2004 Dodge Ram 3500, 4x4 CC, Dually, Cummins 5.9, 4.10 gear, 280k on the clock (no tranny or gear failure), prior to the 04 I had a 99 Dodge Ram 3500 4x4 Dually, Cummins, 3.55 gear (tranny failed at 137k no gear failure), I still own a 2000 Excursion 4x4 7.3 with 380k on the clock (tranny failed at 315k no gear failure), a 2000 F350 SC 2 wheel 7.3 6speed dually with an enclosed utility body (280k no failure) and the wifes 2018 Mustang GT with the 10 speed that is close to 60k with no failures other then a window motor.
Bottom line is, Ford has a problem and they know it. the 21B03 proves that they don't have the parts, they didn't put a mileage limitation on it but it does have an end date.
