10 speed failures
My 22 was a jerk in a couple spots til about 1800 miles last 1k no issues it was getting less frequent then one day it just went away.
Hearing all the tranny issues and rear axle problems makes me want to cancel my 22 F350 7.3 tremor order. I sold my 2008 mega cab diesel after the front end went bad 3 times in 50,000 miles. I have a 2017 F150 now with no issues but MPG goes to crap when towing and it wonders like crazy when passing/getting passed.
As far as getting a loaner I get one if warranty work is being done depending on how busy they are or if its kept over night to repaired. Last time I had to wait 2 weeks to get it fixed due to no loaner vehicle.
I know im very close to trading mine (2020 7.3L) back for something new and hopefully without issues. I love the truck but this tranny can piss rite off. Goes in for a valve body next week but from what i have heard and researched short of replacing the whole tranny these issue linger and to me a truck this pricey and new should have none of these issues period!!! Im close to going with a GMC 3500 but the interiors just arent there yet...... UGHHH im really starting to miss my 2018 F350 6.7
5000 miles on 6.7, no issues at all, smooth as butter. If not under load, it does shift 1-3-5-7-8-9-10, so skips early gears, but still very smooth. If under load in tow mode, then normal gear progression.
Making me wonder about the 7.3 pairing with this 10 gear transmission??
I went with the gasser mainly because my commute to work is 15 min and hardly giving the diesel the running time it wants, not sure if i go back to the diesel and a 2022 F350 and pray i dont get a lemon. Never drove anything but Fords so going to a GMC wont be easy but the new 3500 AT4 sure looks good and the duramax paired with their 10 speed doesnt have the issues Ford is having (that im aware of).
Same here with same shifting and 6.7. No issues whatsoever, just over 8000 miles on it now.
I’m not hearing nightmare stories on the 6.7 in recent year models. Lots of speculation and prior model stories, but seems little substance in actual failure. I drive 30 miles each way to the office, so relatively short commute. I do get extended drive time inside of each 500 mile regen range, no issues so far. It’s early on with only 5k on her, but driving it with confidence and not being scared into modifying how I need to drive. Time will tell. I did buy the Premium Care 7yr/150k from Ford (peace of mind insurance), but more for electronic packages than 6.7 reliability concerns.
Only reason I care is that I have a 22 on order. I’ll stick with a dodge if I’m going to have tranny problems out of the gate
This made me LOL. As a man with a built 48RE to the tune of $7K that's also owned several 68RFE (that RAM's run from 07.5-current) that were unrepairable regardless of how deep your pockets are (until recently, a few builders show promise), and a 21 3500 HO with their Aisin that bangs around; i can promise you the odds are in your favor buying a Super Duty.
Of the SD I've owned, I've never even thought about the trans. That said, my 06 kept me busy rebuilding the motor 2x and the 16 was just flat-out trouble free.
I nit-picks transmissions given every anticipated shift in my Super Duty triggers a bulging vein in my neck thanks to my Ram PTSD. I've noticed nothing in 4.5K miles on my 2022.
Seems most having issues in this thread are 20/21 7.3L; i wonder if they fixed the issue and, if so, if they copped to the causation?
I would imagine this is just statistics:
Number of trucks of a given model year on the road
Percentage of vehicles of a given model year with sufficient mileage to fail (which is itself a spectrum)
Percentage of vehicle owners actively posting on Ford Tremor . com
It also sounds like we have two separate threads here:
1. catastrophic transmission failures (like the OP)
2. rough shifting that may be the result of programming (seemingly solved by a software update per other commenters)
It's likely that most of us 20/21 commenters are running older software.
Good points and methodology!!
My '22 with the 7.3 is butter smooth at 3,4xx miles! LOVE it!
Echoing this with over 2000 miles on the clock with my ‘22 with the 7.3! Transmission definitely had a learning period, but once it got itself sorted it’s quite smooth.
General Motors is having plenty of problems with the GM 10L1000 transmission. Ford led a "joint venture" with GM to build the two 10 speed transmissions......the Ford 10R140 and the GM 10L1000.....the same basic design and engineering with only minor differences. The word is the top Allison engineer took a few quick glances, made a couple of insignificant changes and then slammed the Allison "approval stamp" on it. Both are very complex transmissions.....and can be built for reliability and durability with the correct internal components and parts.
For additional and more detailed information see the following thread ---------->
The Ford 10R140 is designed to skip gears when appropriate.
There are TWO DIFFERENT VERSIONS of Ford 10 speed transmission........the 10R140 behind the 6.7L diesel engine and the 10R140(G) behind the 7.3L gas engine.
Mine is also at the dealer since last Thursday. Had the wrench come on with no drive-ability issue felt. Scanned at work for a trans solenoid code. CEL came on on the way home, about 4 miles each way. Had noise from the trans under the truck and it shifted like crap. Had it towed to dealer and waiting patiently.
UPDATE: Word back from the dealer is there was an internal failure in the transmission at 1,392 miles. With no parts available to overhaul, will likely replace the trans, up to Ford now. I will definately be pushing for a new transmission. Waiting for update on transmission availability and rental truck.
Sure hope you get a new one and the confidence that comes along with that solution. Granted any can have issues, but a repaired unit will take additional time to gain confidence in. Good luck!!
I have a pair of 10 speeds one of each flavor no troubles all good.
