Featured
- #21
Mobil 1 oil and Mobil 1 Filter.
My 7.3 only lasted 29k miles before a full engine replacement so you did better than meyes
with all the electronics especially
never imagined the motor would be a full replacement till around 200k or later?????
so much for the, it's only the low output van fleet motors failing.
had to get more warranty in the middle of the Alaska trip.
4yrs/48k extention
i think im covered 3 1/2more yrs or 115k now.
I've spent about $8k on warranties on the truck so far. curious to see how much that has saved me now. guessing $10k????? or more.
I'll post up the bill when i get the truck back. their initial work time was a couple of weeks. hope to get the truck back next week.
I still can't believe this happened to you brother. We purchased our trucks around the same time and it's just crazy to hear it. Keep us posted.My 7.3 only lasted 29k miles before a full engine replacement so you did better than me
what year?My 7.3 only lasted 29k miles before a full engine replacement so you did better than me
His is a 2022 F350what year?
what was yours doing?
what failed?
Thanks man. All is good now. Hope the new motor is problem freeI still can't believe this happened to you brother. We purchased our trucks around the same time and it's just crazy to hear it. Keep us posted.
Sounds like similiar symptoms to yours. @Optimus posted one of the threads and here is the other:what year?
what failed?
I do or it would act like a vacuum and drain very slowly and pulse. That would take foreverDo you take the fill cap off of the valve cover before you drain it? I do. It's doesn't come out fast, but to me it is an acceptable rate.
I just had the local dealership do an oil change at 1500 miles. I crawled under the truck yesterday afternoon and there was a drop of oil on the filter in the middle bottom. I wiped it off. I was wondering how that got there. I checked the filter and it was tight. I will check again to follow up and see if that drop forms again.When I had a 7.3L I used Mobil 1 religiously and switched to Wix filters. I know there are a lot of fans of Motorcraft filters on here but every one I installed seeped oil from the crimp at the top. Not enough to drip on the floor but annoying.
I just replaced an oil pan and timing chain cover on my VW Alltrack that just turned 100 and it looked brand new inside. Not even a hint of varnish anywhere. Mobil 1 is great.
What’s the reason behind your oil choice?Mobil 1 5W-40 European with the Ford Performance CM-6731 FL-820 filter. I also use the Stahlbus drain valve.
Full SAP’s and HTHS is > or = to 3.5. Meets specs for MB 229.5 and Porsche A40. It is a very robust oil that is readily available at Walmart for a reasonable price.What’s the reason behind your oil choice?
