What octane of fuel do you run with the 7.3l?
For most vehicles, Ford actively develops the calibration for higher octane to establish the max performance, fuel economy, etc and then "detunes" for lower/base octane while meeting all the program goals. This also ensures safe operation and lower risk of engine damage for the majority of owners. Not all engines will respond to increased octane due to the design of the combustion chamber, ports, injection strategy, however... Other OEMs will take a more blended approach - seems like Honda follows this strategy looking at the numbers above.
That's a good point. The higher octane may be better for those who add a custome tune to the engine or add a Whipple or Procharger.
Ford 7.3-Liter Godzilla V8 Dyno Run Reveals 348 RWHP With 93-Octane Tune
Well, I run 87, manual says you can and it works. My GT500 calls for 91 and I have run 87 in it because I was in a pinch, granted didnt put it in to boost, but it was fine for a tank full.
As far as C&D test, I dunno, seems like a lot of HPO gains for just 5-6 octane. I have seen CAI claim to add 25 HP and that is skeptical, but the F150 20HP? or even the R/T 14HP?
Mostly 93 octane. Switching to a tank of 93 after a long use of 87 does not yield to optimum gains within a tank so if you are occasional 93 but mostly 87oct user next time you do the switch try a couple of tanks.
Noticable power and fuel mileage gains are more pronounced on turbo engines but on mine i get .5 mpg better and truck feels more peppy.
I know this thread is a year old but curious for anyone towing horses what do you guys use? This is my first Ford and also first time I'll be pulling horses, mostly a 2 horse trailer but maybe pull 4 horse. I only have 800 miles on my 24 F250 so far and been using 87 but haven't towed anything yet.
If you’re in an area where you can get ethanol free gas I would recommend filling up with that at least once a month to help keep things clean in fuel systems.
I use 87 and that’s all I ever plan to use in this thing. Stock engine tune.
The wife’s Bronco 2.7 gets 93. It makes a noticeable difference in Ecoboost engines over 87 even on the stock engine tune. Runs smoother and get an extra 40-50 miles a tank over 87.
I'm sure it's been said in the earlier pages, but I don't want to read through 5 pages to find it. The only difference between grades is the stability of the fuel in heat. Basically, higher octane only reduces detonation. This is necessary in high compression engines (supercharged, turbo, and 12:1 higher ratio). In our 7.3 the higher compression will do nothing. The knock sensors monitor the engine at something like 1,000 times per minute and adjust the timing, advance, etc. to prevent detonation. Can you run a higher octane in the 7.3? Sure, the computer will detect the higher octane in the sense that it does not need to retard timing to prevent the detonation. This could, in theory provide more HP but you're talking near minimal gains in these engines.
For towing, it won't make any difference. If you're climbing interstate 70 from Denver toward Grand Junction at max GCW and basically keeping the engine at redline the whole way, you might see a difference. But I wouldn't bother.
As a flip side, you can run 87 in a car that recommends 93. But you won't be able to revs the tits out of the engine. The knock sensors will do all in their power to protect the engine.
I think youre downplaying the gains timing can get you, but otherwise pretty spot on.
Not maliciously. There are gains to be had by timing changes, for sure. But those gains are going to be relatively smaller in a N/A truck designed engine versus a F/I performance designed engine. Which is more of what I was driving at. If we're talking about my 4.2 liter supercharged Jag engine in my Range Rover, then yeah, 93 is going to make a marked increased in horse power compared to 87. But in my Tremor it's going to be a smaller overall gain and probably not noticed by the user.
There's a post above about the octane differences in a Bronco. Which I would expect given it's a turbocharged, higher compression engine.
I run 87 until temps start to consistently get above 90 degrees and then I will run 89 until it cools off again (basically from May/June through September). It gets really hot and dry here in the summer, and the truck runs noticeably worse if I stick with 87 even unloaded, I wouldnt feel comfortable towing or hauling something heavy without running 89 or better in those situations.
Or if I am somewhere (usually higher altitude) where "regular" is 85 then I'll fill it with mid-grade.
I drove a tuned F150 for 7 years (good ole 5.4l 3V, with Kooks long tube headers and a 3.5" exhaust and some intake mods), there were times where I was annoyed having to always fill with 91+ but stock that truck was completely lifeless, so I was happy for the extra power.
Unless you're running a high compression engine (including boosted or turbocharged inlets), %ethanol is more important than overall octane rating. This is because, as all the little pump stickers will tell you, "octane" on the pump isn't ACTUAL octane. Instead, it is blended with ethanol and calculated to be equivalent to a true amount of octane in terms of it's stability in resisting detonation. This is why regular 87 octane gives better gas mileage than 15%-ethanol "88 octane", and WAY more gas mileage than E85, which by the same calculation method is the equivalent of 108 octane. What's particularly interesting is that if you were to buy 93 octane and go through the process of removing all of the ethanol (you can Google how to do this using water as a means of separating out the hydrophilic ethanol from the hydrophobic octane) you are left with something that is roughly equivalent of regular 87 octane (removing the ethanol makes it more stable for storage). Higher octane fuels achieve their higher octane rating mostly by increasing the amount of ethanol over lower octane blends.
So, in general, the octane rating on ethanol-blended fuel tells you how stable the fuel is against detonation, but doesn't actually offer additional energy density in the fuel itself. In fact, if you just Google the question "does higher octane fuel have more energy?" the answer you get is "no".
-SR-
Octane is an index number assigned to the resistance of fuel to "pre-ignite" meaning it lights before the ignition system starts it.
Pre-ignition or detonation occurs when the flame front collides with itself and is typically caused by hot spots (IE carbon deposits) within the cylinder or combustion chamber that starts the combustion process by more than the intended ignition source.
Everything built within the last 3 decades (vehicles with gas engines of course) are equipped with detonation sensors, which is a piezo-electric sensor that generates a signal based on a "specific tuned frequency". When the PCM receives this signal which is pre-ignition or detonation, the timing is retarded to eliminate it.
Now, with all of this basic background stated in simple and generic terms, let's look at the effect of octane.
Higher octane (higher index number) gasoline has a higher resistance to pre-ignition or detonation. It is less flammable than lower octane fuel and thereby produces less BTU per pound. Using higher octane gasoline in vehicles that do not require it can lead to building carbon deposits in the cylinder and combustion chamber at a higher rate than what would happen with a lower octane gas.
In other words, if FMC says 87 octane is fine, then use 87 octane.
87 octane ethanol VS 87 octane pure gas.
Ethanol by nature has a much higher octane rating than gasoline, in fact the BTU per pound is roughly half of gasoline. Which explains why a race car on alcohol takes nearly 2 x the amount for the same horsepower.
All alcohol is hygroscopic (meaning it attracts moisture) and can become very corrosive by nature.
Alcohol at proper levels mixed with gasoline is approved by vehicle manufacturers, E-85 can only be used in vehicles specifically equipped to use it.
In the end, pure gas is the best thing to use if it is available in your area and within your budget. Most places around here (NC) get upwards of an additional $1 per gallon, which makes it not cost effective for vehicle use. However, I always used it in my boats and continue to use it in all of my small engines.
I own a fillin’ station. This is the absolute best answer to this question and well written to boot.
I think people get it in their head that "higher octane = higher performance" because the higher octane fuel is typically required by higher performance engines due to the higher compression ratio and need for more knock resistance, so high octane becomes associated with high performance, even though the higher performance isn't being generated by the higher octane, but rather the higher compression.
-SR-
-SR-
I think it's interesting how many people don't register the energy density between gasoline and ethanol blends. E85 does have a higher octane but the ability to do work is lower hence less mileage per tank.
My SiL's family is from Brasil where they very regularly have both pure and ethanol blends on tap. They tell me they have a rule of thumb based on cost per mile. I don't recall the numbers, but they will fill up based on which is the lower cost per mile given the range difference per tank.
I've never run higher than 87 in mine for the past five years. I don't think there's any recommendation to run higher either. I have heard a ping or two right at first fire on a hot startup, as in hot day and engine is hot. But never have I ever heard any prolonged pinging at any other time. Running higher octane gives you no benefits other than detonation protection, which isn't needed on these engines, unless you really like spending extra money.
