In terms of its octane rating, ethanol has a rating of 113. As mentioned above, fuels with a higher octane rating reduce engine knocking and perform better. Also, almost all gasoline in the US contains 10 percent ethanol. When you mix 10 percent 113 octane ethanol with 85 octane gasoline it increases the octane two points to the normal 87 octane most consumers use. So the higher the ethanol content, the higher the octane. The octane rating for E15 (15% ethanol) is 88 octane and E85 (85% ethanol) is 108 octane.
I knew a person who worked at Sunoco cracking fuels when they actually produced most of there own ,there not making and storing higher base for all fuels 88 , 89 , 90 ‘92,93 and now 94 …ethanol amounts can be all over the board , I have seen loads of fuel that left the plant , ethanol was blended at the end of the process . It is far from a exact process
I use the cheapest but like to believe Costco is high quality fuel with detergents , I use 87in the 7.3 unless I’m near a E0 pump like in Florida running a 100% gas 92 octane
