What octane of fuel do you run with the 7.3l?
interesting, never noticed that. never seen a vehicle recommend an octane range before. i'll check that tag.
Many Ford vehicles take that approach. The calibrations are safe to run on lower octane fuel and generally that is what most people do. For those that want more performance the cal will allow more aggressive spark when it senses the higher octane fuel. There are some vehicles that specify "premium fuel required" and are calibrated accordingly.
i've only had 2, and couple hondas and toyotas, never heard that before but never really looked either. i know you can run premium even if not required, but never knew f250, for an example, recommended one but could run on another. think only time i heard that were these "performance" sedans like infinity or whatever.
there a reason anyone runs premium in these? from what i remember, u only run premium when you need to. if you don't know, you don't need to. running premium i think costs power. only reason tuned engines run em is so you don't have to retard timing as much, or soemthing like that. havne't messed with my tune in forever.
On the tag near the gas cap it states you can use 87 but for the best engine performance 93 is recommended.
Bingo! Not only on the tag, but in the owner's manual (page 204 of the 22MY manual):
As you said, a core reason to run a higher octane fuel is when you're pushing timing to get more power out of the engine. In older cars, that was a manual operation. If you weren't messing with the timing yourself, putting a higher octane fuel in does nothing.
Many (most?) newer vehicles - including our 7.3L Super Duty's - have Variable Valve Timing (VVT). That means the computer can change the timing on the fly, whenever it wants. Combined with a method for checking the octane of the fuel, it means it can adjust the timing to get the most power out of the fuel (within safe ranges, of course).
I believe the way it does this is, at some strategic point, adjusting the timing to be more aggressive and seeing when small knocks are detected. When they are, it backs off the timing a bit and calls it good. So it's indirectly checking the octane rating.
It's worth noting that this doesn't mean you're required to use an octane rating higher than 87 at any time. Just that you're most likely to benefit from it in certain conditions.
Edit: also computer controlled spark, so it can change at any time when the spark happens in the engine cycle.
Might be a newer vehicle thing my 2020 doesn’t have a tag or any writing on what octane to use the cap does say E0 - E15. The owners manual does state min use of 87 and 91 or greater for peak performance.
possibly, my previous fords were 2000 and 2011. interesting, new tech.
Yep. And when the intake air temperature is higher, and load is higher (ie, towing in the summer), you're more likely to experience pre-detonation, thus 91 helps reduce this effect and allows some advanced timing (or retaining regular, non-retarded timing). So your supposition is correct.
@ccw @Tuxedomouse that is the main input to determine octane (or lack of), however, there is another key portion of the closed loop control - the Oxygen sensor. The algorithm is proprietary to each OEM, but at any engine speed/load point there will be an threshold of max spark advance and leanest fuel (relatively) to achieve the highest torque. This is not just at the highest point on the published SAE torque curve, but at all points of the 3D map. Knock, even inaudible, is a clear limit. Without that indicator the combustion efficiency can be picked up by the O2 sensor and adjusted accordingly...
What octane are the 7.3 folks running these days. 87,88 or 91. … ?
I don't run a gasser Ford, but I run whatever non ethanol gas I can get fo all gas engines. I don't care what the octanbe is.
I run 87 usually, tried 93 for a time. Not much difference. Also in my area we have 88 e15 and it runs great on that also. Mileage doesn’t change much for me. Ford says anything e0 - e15
I've generally run 87 running empty. Towing the camper I'm planning to experiment a little just for fun but my guess is I'll probably end up using 87 all the time. I think under very heavy work conditions, such as pulling in the mountains in higher mid-summer temps, you may end up with a little bit of pre-ignition knock. If you detect this ever it would be wise to fill up with 93 to prevent the engine knock. If you don't experience this there's no worries.
BTW if you ever experience pre-ignition know while driving, if you carry bottle of Octane booster with you in the truck, you can just pull over and add that to the gas tank and not have to drive the truck until the next fill up of 93 grade. Pre-ignition knock is pretty hard on the engine and it's not a bad idea to have a bottle handy just in case. Again, I've not experienced it and it may never happen. Sometimes it can occur due to having to fill up with cheap fuel at a lower grade station. A bottle of octane booster is very cheap insurance to have along.
run 87 most of the time
87, unless I was also filling cans for power equipment then it was 89. No difference between the two in the truck, it was just a convenience thing...
87 all the time. No reason to throw money away. You are not benefiting from the slight power increase even when towing. 87 is acceptable according to the manual and I have never experienced knocking. I didn't notice any increase in mpg with higher octane while towing (offset the price difference). But hey it's your money. If you want artificial piece of mind then have at it. 😉
Car and Driver did an interesting study on the benefits of putting in the high octane gas. Of course, you'll have to decide if this is worth the added cost.
Is Premium Gas Worth It? We Test High Octane on 4 Popular Vehicles
Here's the summary of their tests:
For most vehicles, Ford actively develops the calibration for higher octane to establish the max performance, fuel economy, etc and then "detunes" for lower/base octane while meeting all the program goals. This also ensures safe operation and lower risk of engine damage for the majority of owners. Not all engines will respond to increased octane due to the design of the combustion chamber, ports, injection strategy, however... Other OEMs will take a more blended approach - seems like Honda follows this strategy looking at the numbers above.
