What is the best tuner for the 6.7 Diesel?
I'm curious if we can swap the 2 ECU's back and forth for warranty reasons at the dealer.
You’d have to call in and ask I’m not sure if it be that simple or not, theoretically it should be but I’m not a 100% on that
Those power numbers are normal for emissions intact tuning, used to be $900 for ecm and tcm tuning and another $450 for an ez-lynk so $1350. Deleted tuning would push closer to 200hp because you could lay the fuel to it a bit more. Even though I’ve been foaming at the mouth waiting for this I just can’t swallow $3450 to pick up 100hp and still have to worry about the emission garbage if they kept it around the 20-21 trucks price $2250 (which is still pricey) I think I woulda said screw and got it
Sure, but I guess since there aren’t many options for 22s, maybe they’re taking advantage of a “first to market” type situation. I’m sure once other options arrive, price could go down. I have a feeling vehicles are gonna get harder and harder to crack as the push towards all this autonomous driving stuff keeps rolling out.
I think you probably spot on there, the level of ecm encryption has gotten insane
Different strokes for different folks.
In today's world, the purpose of a "tune" is to omit the unecessary clutter diesel engines come with. They run perfectly fine and even better without the added garbage that have been added on to keep a certain crowd happy. Likewise, just that notion alone makes these engines even more powerful by allowing them to breath restrictive free -- a "tune" in itself.
Having said that, the power number these engine already make are in itself astronomical, pushing more HP/TQ than 18-wheelers.
By adding more juice to a restricted engine, I would be led to believe you're only adding more harm to foul already. Paired with a forced computer generated cleaning cycle to declutter everything that is has been collecting that should have been cleaned out on its own to begin with. Not to mention the continous feeding of animal urine to its gut - what a joke.
If I am spening that kind of money, I better not be buying animal urine ever again and let that puppy breath!
That’s for a 20 maybe the 22’s are more plus don’t forget it also has to be unlocked to be tunable
From what I've been gathering anything 20+ is the same ECU. Just the 22's have the encryption on them? Sorry still kinda new to this
I'll be 20 minutes from there store this weekend so if I have time I might stop in and talk to them on it. My guess is the truck will only accept one ecu and it would be a lot of programming work for things to work electronically, physically somewhat of an easy swap.
My guess would be you aren't getting a "22" ECU as an ECU from that model year would have corresponding encryption from factory (also assuming these come from Ford somehow). My conversations with them previously stated that in order to tune a 22 an ECU swap would be required (this kit). Thinking they are buying and some what pre-programming the '20 or '21s since they have the ability to unlock those, for this application.
This is complete speculation BTW, I have no idea what they are actually doing...
From what I've been reading it doesn't sound like the trans is up for taking much more power than stock.
Not sure what you’ve been reading but this is probably the best diesel trans out there, bump up the line pressures and tweak shift strategies and lock-up which is part of the trans tuning that’s included, it’ll be fine the trans would be the least of my worries I’d be more worried about the freaken cp4 that ford insist on using and the emissions system
Which means price isnt gonna be cheaper
Agreed, but at a certain point it’s just not worth it and for me this has gone well past that threshold
So I have been testing out edge’s ez x for the 2020+ power stroke and I have been loving it. I have the power adjustments which are fine but I can adjust just about anything I need to from my phone but from what I understand they are going to load it onto the insight display possibly too. Should be out soon but so far I am a fan.
isThis a piggyback system like banks and others (like a jb4 or RaceChip on a lot of gas vehicles)?
NM, Thought your question was for the calibrated power setup.
edit: Reading is fundamental...
Just my 2 cents, and I am sure I'm not wanting to achieve what some of you are. I have a '21 Tremor 6.7 and have only the Banks Pedal Monster. This device has more than enhanced the throttle response and given me the sometimes needed power to pull into traffic or pass. As we know this is not a tuner, but accomplishes what most are looking forward to achieving with their 6.7. It can be removed with no footprint left. Now for the people towing to the engines limit I see the need for a tuner
Sweet, didn’t realize the black box tuning still required an ecm swap which may work out for the better at least you’ll have your stock ecm if needed
The Black box does not require a swap, i loaded mine in my driveway and everything was pretty easy.
Not for a 22 to my knowledge
I wanted to give my overall impression now that i have had the Duramax Blackbox tuner for a few months and i have now used all the modes. I purchased the ECM and TCM SOTF package
Sport mode - Really only good for racing IMO, 2-3 MPG's hit, only ran it for a few days to check my 0-60 and 1/4 mile times. Honestly you cant even step on the pedal without spinning tires and slowing down unless you put it in sporttrac mode, 4x4 and turn on lockers, too much power. But hell yes once you're moving; this truck is fast.
Street mode - Fun to drive every day, but 1-2 MPG drop. Drives real smooth and truck is a lot faster that it was even with my stealth module.
Light tow - My favorite everyday drive mode, slight MPG gain, still a lot faster that stock/w stealth module. Smooth and faster than everyone else. I have the forscan and monitor my regens, and it regens less.
Heavy tow - I really couldn't feel much of a difference with my 13k fifth-wheel, but the truck pulled like a beast before. Did get a slight MPG increase on my 400 mile trip from last year, and thats even with winter mix.
Modify stock - Drove like a stock truck, and you can really feel how much slower the truck is in this mode. Slight MPG increase.
I am seeing my MPGs increase as my tranmission relearns, it did the same thing with my stealth module. At first i was thinking i made a mistake, and now i am getting better MPGs. So do i think its worth it??????? I was getting on the I-20 and tried to pass a raptor who apparently didn't want me to be in front of him, blew by him going well over 100......so hell yeah! BTW...that was in light tow, I forgot I could switch to sports mode like a noob.
Is yours a MY ‘22?
edit:Cux211 beat me to it.
The website on duramax websites says blackbox(on the bottom) for the 22, that is what you will plug into your ECM to program it yourself. Its different from previous tunes i have done. Your ECM tune is under the hood, your TCM is through your OBDII inside your truck. With the black box you will download your stock file, email it to them and in about three days you get your SOTF tunes.
Unless I am missing something, this is the one I am seeing for MY 22: https://duramaxtuner.com/diesel-tun...witch-on-the-fly-ecm-and-tcm-tuning-2022.html
The blackbox only (no ECM swap) is only listed for 20 and 21 model years.
