What is the best tuner for the 6.7 Diesel?
The website on duramax websites says blackbox(on the bottom) for the 22, that is what you will plug into your ECM to program it yourself. Its different from previous tunes i have done. Your ECM tune is under the hood, your TCM is through your OBDII inside your truck. With the black box you will download your stock file, email it to them and in about three days you get your SOTF tunes.
That is for 20-21, 22’s require a second ecm that’s why it’s $3500 for tuning and gives you 2 hours of phone time with a dmax tuner tech to help you clone your ecm to the second ecm they send you
I watched the video, and it is an ECM swap? i Guess I am not sure why you need to buy an additional ECM and they walk you through a two hour process. Sounds like ford is preventing us from modifying our trucks. Cool thing is you can swap the stock one if you needed too.
I believe it is because they have not broken the encryption on the MY 22s yet. They can read them but not write (tune) to them. So they pull the configs from the factory ECM (for a 22) and have you write that config onto the purchased earlier model year ECM.
From what I was told it’s not a previous year ecm it’s basically the same thing they did with the L5P dmax’s when hp tuners bought a shit load of ecm’s from gm, physically got into them to modify to be able to be tuned
I assume that's what drives the cost of the ECM from them then.
Yep, but for me at that point just tuning and still dealing with the emissions garbage at $3200 nope I’m out
I hear ya, a bit steep to adhere to the rules for a little gain and continue to deal with clogging the DPF (probably quicker).
