??? Using the light dimming sensor at the center dash
HeavyAssault
I'm just here to argue over your dumb posts
(Space for rent)
>>US Army<<
First Responder
Is she DAF or just ignoring me??
2022 F350 CCLB (11/2022)
2015 F350 CCLB 225k // 2006 F350 CCLB 280k
Anyone with some Ford electrical schematics share some info. Hoping to be able to locate the output wire that triggers based on the light level. I'm pretty sure it's nothing different than a trigger wire that once the outside light reaches (say XX%) it activates a relay to the system, dimming the dash, activating headlights....etc etc etc.
What I would do is use that same output signal to a relay to activate (insert cool truck thingy). Say other exterior lights, or other function....
All help is greatly appreciated.
I don't know if you'd want to tap directly into the output for that sensor, i suspect it'll be a low voltage signal wire and probably not strong enough for a relay. I'm not quoting anything, I'm guessing based on the systems in our trucks.
You might have better luck tapping into the headlight switch and finding the output from there that turns on the night time illumination in the truck. Parking light wire would be a decent option.
That's what I wanted to understand/verify. Either it's receiving/feeding a 5V signal, or higher...maybe even lower.
I got to take apart the dash for the BuiltRight dash stuff so I wanted to try to do 16 things at once. 🤣 🤣 🤣
So, i'm reading the service manual. Looks like it's an analog signal. Doesn't specifically say analog nor does it say 4-20mA 0-10V etc. What it does say is that it "supplies information to the FCIM indicating the intensity of the sun on the vehicle. The FCIM compensates high sun load with higher blower and reduced discharge temperatures." Which leads to me believe it's analog.
ETA: apparently there are two sensors in the sensor; one left and one right.
So help me with the analog signal aspect. Is that meaning it's just straight voltage in-voltage out?? Like a pressure sensor??
No, it's providing a range of signal values. If I use a 0-10v type signal: 10v output from the "sunload sensor" (official name) would indicate direct, unobstructed sunlight. The computer would then adjust accordingly, higher HVAC speeds, head lights off, etc.
Where as 0V would indicate pitch black. The computer would then know to turn on the headlights. Maybe the AC doesn't need to be blowing so hard, etc.
What signal triggers responses in the computer aren't stated in this manual. Sticking with the 0-10V signal, it's probably a 4V signal that turns on the head lights and maybe a 8V signal that increases the HVAC speed. I'm 100% guessing here.
If you tap into the signal you'll alter the values and mess up the computers understanding of what's happening. By how much, i can't say. But adding a load would cause the systems to function incorrectly.
Oh...I get it now. Damn...I was sort of hoping that dash sensor was just dumb. :sneaky: :sneaky: :sneaky: 🤣🤣
BTW...FCIM?? Description??
Front Controls Interface Module. One of the computers. These trucks have about 25 of them all connected on a high speed network.
Okay...anything connected to anything called "Module" needs to be handled with caution. Guess I'll figure this out another way then.
Tapped into the snowplow plug to pull park lights and high beams. Not much more there though.
Park lights turning on the backlight of the KC's is cool; bonus feature it blinks with the lock button
Do you have any pics of the wiring you did to tap into the snowplow connection??
this post
and this thread
The snow plow connector is probably your best bet for anything you want triggered by the lighting system on the truck. The connector is powered by relays powered by the Modules so you don't run any risk of damaging the factory components.
