Upfitter Switches
I have been thinking of installing some lights under the truck in a few spots in case I need light to work on something or if I'm off road and something goes down. I know a flashlight will work too, but holding a flashlight to repair something sucks.
Get some magnetic rock lights
I just carry a headlamp in the truck for that. Hands free flash light!
Where are you mounting the compressors on your Tremor?
In the bed on a Builtright panel. Didn’t lose enough space to be concerned with it and it’s protected from the elements with the roll top cover.
There's wires both in the passenger foot well and engine bay. You can use either depending on what's more convenient.
I be finally had some time to go looking for these wires. The ones in the engine bay I found easily enough. I can’t find them in the footwell (right). I found 4 big wires that terminate as one, and a lot of smaller wires that terminate individually. One of them is the correct colour code, but it has 3v or so when the engine is on and is much smaller than a wire designed to carry 25amps. Do you have any further information as to exactly where the wires are please?
Need to run out to my truck for something else. Will take another look while I'm out there. Maybe I was mistaken.
The four wires that you say terminate as one are the pass-thru wires. Take the black “terminating” point off…. Then you have four wires. The same four wires are behind the passenger kick panel. There is no voltage to any of these wires until you connect them to a voltage source such as the upfitter wires.
Ok, I am a bit confused. Hoping you can clarify. What are the pass through wires, I haven’t heard of them before? Do you mean wires that come through the firewall? So does that mean they have to be connected to the upfitter wires in the engine bay?
Ok, so here’s what I have in my kick panel:
The bundle of dead-end wires hanging lowest in the picture is related to the PTO.
The small bundle of wires all heat shrunk together on the right of the picture are the pass-through wires as far as I’m aware. I am very intrigued that it’s only 4 wires, though, given there’s a total of 6 switches.
Under the hood appears to be a matching bundle of wires terminated with heat shrink. You can see them in the center of the picture below. I didn’t want to pull them out right now since they’re nicely taped up. This is the passenger side of the engine bay next to the fuse box.
The colors of the bundles appear to match each other.
My understanding of using the pass through wires is those are hot wires when the switch is on. Both the engine bay and passenger footwell wires corresponding to a given switch will go hot when the switch is on, so you can use either or both wires as you need.
Pass throughs aren't hot until attached to a hot wire from either side. They are not hooked up to a switch until you hook them to a switch. They only "pass through" from interior to engine compartment. Ford provides these so you don't have to run wires through the firewall......thoughtful aren't they
correct
If that’s the case, where are the wires in the engine bay that are actually hooked to the switches?
Alternatively, where do the pass through wires terminate in the engine bay?
Are the wires I’m showing in my engine bay picture just the other end of the pass through wires?
The upfitter wires are under the upfitter relay/fuse box beside the battery. It's the box just to the right of the negative terminal of your battery in your picture. Release the two clips on the box and it will lift up revealing said wires.
The passthrough wires in the engine bay are just under the cowl lip beside the upfitter relay/fuse box. The wires are usually "taped" to the wiring harness.
I can take pics in the morning if you wish.
Ohhh I see now. The black mass in the picture.
The owners manual sort of explains all of this on page 619......I think that's the correct page
Ah yep. It does, but I think it’s a lot more clear once you already understand what to expect. 🤣
Thanks for clearing it all up!
