Upfitter Switches
The upfitter wires are under the upfitter relay/fuse box beside the battery. It's the box just to the right of the negative terminal of your battery in your picture. Release the two clips on the box and it will lift up revealing said wires.
The passthrough wires in the engine bay are just under the cowl lip beside the upfitter relay/fuse box. The wires are usually "taped" to the wiring harness.
I can take pics in the morning if you wish.
Please do
I opened up the loom that contains the upfitter wires and found a few other wires as well. Only one of those wire has the same colour and trace as the ones in the footwell. It’s not the same wire. So I’m back to square 1. I have a plan if I can’t find the pass through wires in the engine bay but I’d rather use them if I can. I suspect the 21 and 22 might be different.
The upfitter wires and the pass-through wires are not color coded the same…..they don’t need to be.
Yes. However, the other wires I found in the engine bay aren’t the same colour as the wires in the footwell. Someone stuck a brake master cylinder and booster
in the way which doesn’t help!
use them for whatever you want or nothing at all. not all hooked up yet but this is my layout
1. front led light bar
2. rear led back up lights
3. puddle lights
4. air compressor
5. cellular signal booster
6. ham radio
That’s a great layout, thank you for sharing!
How come no one is using switches 5 or 6 for the compressor, seemed like it would be hand if you wanted to air something up without running the truck?
Usually it's a good idea to have the truck running while running the compressor. It's a high amp draw so will drain your battery quickly, and it will also work better/faster with the higher voltage put out by the alternator.
While I'm not going with OBA (at least not for a while), that would be my logic.
Amp draw is too high. Best to run the truck or you’ll kill the battery. For example the arb twin has a draw of 50 amps under load. That’s also the max of that circuit. Best to run straight to the battery and use the switches to run a relay instead
I contacted ARB before installing mine. They said that any switch will work causing it’s only turning it on and then the twin has its own circuitry to draw needed amperage to run the compressor. ARB also stated to use it with the truck running.
Was originally going to out it on 6 but CCWs answer was exactly my thinking. Figured not giving me the option to run with the truck off would prevent me from killing the battery. Figure these are better saved for something I can/will use with the truck off.
That’s what I thought but I had an arb twin in my doge fields that was hot wired on. I’d use to Reinglate my tires sometimes with the truck not running, was never an issue. Was wondering if there was some other reason. Guess lights that would stay on without the key on is nice
Ya my use for one of the always hot switches will be radios and lights. Though they won't be powered directly by the switch. Instead I'll have a dedicated power feed that the switch controls with a low voltage cut-off protecting the starter batteries from being drained.
Agree with this logic. I like having inherent process steps that protect us from ourselves. :p
