I believe the first notice/supplement only listed vehicles with 4.88 ratios, and didn’t specify diesel. Since all Tremor 6.7 vehicles are equipped with a 3.55, and since the 7.3 gas Tremors are not dieselsI dont get it. Maybe I am reading it wrong. Supplement 2 says additional vehicles are eligible including those with axle ratios of 4.30. I didn't think that you could get a diesel in 4.30 axle ratio.
Rough down shifts often dead pedal, jerky feeling sometimes. 100% agree with you about under load. Even my small dump trailer loaded up makes it so much smoother.What issue do you have with yours? The 7.3 likes to drive under load. When it's empty, the shifting is a little awkward almost like it's looking for the next gear.
Since all Tremor 6.7 vehicles are equipped with a 3.55, and since the 7.3 gas Tremors are not diesels, then all Tremor SDs should essentially be unaffected by this CSP.
Very true. I love the way mine drives with my trailer. Does feel a little awkward with no load especially at low speeds. On the bright side if no 7.3's are affected then it should be slighty more managable for Ford to deal with hopefully making it easier for those affected.What issue do you have with yours? The 7.3 likes to drive under load. When it's empty, the shifting is a little awkward almost like it's looking for the next gear.
I agree, my brothers friend is a ford mechanic and he was saying on the 17s and newer when they pull the trans there is some bolt that is hard to get to so they typically just leave it out on reassembly maybe that was only the 6 speed, maybe he made it up but I have had a enough terrible experiences with warranty repairs I wouldn't want them rebuilding my tranny, at least not my dealer.Yep, definitely want to wait until techs can figure out which parts are unnecessary and which steps are time wasters. I can see those 16 little gaskets being reused and about half these pages skipped.
This is quite a pickle. I absolutely don't trust the dealer techs to go through these steps, especially if they have a line of trucks that need the same thing. But what else are you going to do?
I'd of course rather a new trans and let Ford mess around with the bearing and such at their own risk, but I doubt they'll go for that. An extended warranty would be nice.
Looks normal, if you are talking about the part not painted on the slip yoke.Anyone have a problem like this?
So that’s normal weird. It slings a little oil and on a hard take off the 3rd to 4th shift won’t happen unless I take my foot off the peddleLooks normal, if you are talking about the part not painted on the slip yoke.
The part in your picture is connected to the transfer case and has nothing to do with regular shifting, that would be the transmission which does not sound normal.So that’s normal weird. It slings a little oil and on a hard take off the 3rd to 4th shift won’t happen unless I take my foot off the peddle
Ok thanks for the info. Just got off the phone and have appointment set to have it looked at.The part in your picture is connected to the transfer case and has nothing to do with regular shifting, that would be the transmission which does not sound normal.
What is supposed to be the problem. Please be specific. If you are seeing the shiney area on the slip yoke, that is normal as the yoke slides in and out. It shouldn'tleak any fluid but there may be normal sign of of a small amount from assembly. If.leaks more than that it may need a seal and bushing.Ok thanks for the info. Just got off the phone and have appointment set to have it looked at.
Normal.Anyone have a problem like this?
