The exact date is bottom right on window sticker. My door Jam say 3-21. Window sticker says 03 08 21Where do I find out the date of assembly at? Am I overlooking it on the window sticker? Or is it on the truck somewhere?
if i am seeing it correctly then, mine was 11-19-19The exact date is bottom right on window sticker. My door Jam say 3-21. Window sticker says 03 08 21
Because its not a recall, it's a customer satisfaction programI called my local dealer today, spoke with service. The guy told me that he hasn't heard anything about this recall, that there is nothing in the system for a transmission recall on my truck. My build date is February of 2020.
What's up?
I saw this too. What exactly is a CSP vs recall? If they know they have a manufacturing defect why is it not just recalled to get it fixed? So I guess people either have to have problems with their trans or see the CSP on internet forums then go ask their dealer about them? It just doesn't make sense (i know, i know, costs money) why Ford knows there is a defect, yet doesn't/isn't upfront with the customer or the dealers about the issue?Because its not a recall, it's a customer satisfaction program
My dealer told me to bring them the truck and if they can get it to show a fault or act up while they have it then Ford will allow this (recall job) if it wont do it while they have it then no luck. My hard shifts and issues are not consistent enough to even waste my time taking it in yet. Which sucks because in a way im hoping it gets worse so they fix it before it expires.......
The flip side of this is the aftermarket techs work on all brands and probly get very good at the brands they see most often. ie; Ram trucks and a few others. But the Ford techs only work on one brand and get very efficient in that. Repetition helps with familiarity and quality of repairs. Not forgetting that Ford dealers have the special tools, test equipment, software and access to Hot-line when needed. Dealers can only get paid for Trans warranty claims performed by Trans Certified Techs. IMHO there are a lot of good Trans Techs both Ford and Aftermarket and some lesser capable techs in both also, like in any profession its all about the people. But for some to single out Dealers as lesser quality or qualified is far from the truth as I originally said. Some bash Dealers continually and don't really think about the Individuals performing the repairs. Its all about the people. Please take no offense here just my experienced opinion.Maybe but I have my own close friend that owns a transmission and engine shop . I know for certain they rebuild more trans than all of the ford dealerships in the area combined. They can "fluff" through the program. same can be said about front end alignments. They may have the tools and some training but the techs at the dealership do so many other things they are not experts at one
That isn't always the build date. It isn't on mine.The exact date is bottom right on window sticker. My door Jam say 3-21. Window sticker says 03 08 21
Should be on the window sticker if you still have it.I have Date: 8/20
VIN: 1FT8W2BT3LEE41908
How do I know what date in August?
Is this my window sticker build date? Which is what to go by? ThanksShould be on the window sticker if you still have it.
Check my post above, it's close but not exact. You may not need the exact date though unless you are on the fringe like I was. Looks like you're in the clear.Is this my window sticker build date? Which is what to go by? Thanks
12-15-20Is this my window sticker build date? Which is what to go by? Thanks
That’s good to know. Can the dealer provide you with actual build date and build sheet?That isn't always the build date. It isn't on mine.
my window sticker says Jul-27, Door sticker says Aug-2020 and actual build date was Aug-05
I don't know about the build sheet but my brother is a tech so I got him to lookup my build date.That’s good to know. Can the dealer provide you with actual build date and build sheet?
