Transmission CSP 21B03 - Planetary Gear Replacement in 10 Speed
What is supposed to be the problem. Please be specific. If you are seeing the shiney area on the slip yoke, that is normal as the yoke slides in and out. It shouldn'tleak any fluid but there may be normal sign of of a small amount from assembly. If.leaks more than that it may need a seal and bushing.
To be honest I feel dumb now cause I know that is a slip yoke but it slipped my mind. It has some oil/Grease spun on the bottom of the cab. That’s what the warranty is for.
Slip yoke slipped your mind...I see what you did there! :ROFLMAO:
My 2020 F350 7.3 Tremor 26k miles, 1/31 build date with I believe has 4.3 rear included is experiencing same problems. Why it's not included as of yet is beyond me. Filed a complaint with NTSA. Guess I'll contact them and notify of this current recall and that the 7.3 should also be included.
ALL dealers in my area(Vegas) have over 1 month wait for appointment to look at. Called Ford and ZERO help other than make an appointment for me. Went there and was told leave it with them and they'll check it in 4-5 weeks. No loaner offered or available till diagnosed....WHAT A JOKE!
Going to try getting some higher ups involved at Ford to accelerate the addition and expand this recall as it's DEFINITELY NOT SAFE TO DRIVE. Almost got hit when my truck went limp at 2 way stop and left me in middle of road (DEAD PEDAL) with vehicles approaching on both side. When it finally downshifts from 10th or 7th that it was stuck in it's extremely abrupt and bangs the gear VERY hard. $70k PAPER WEIGHT....
Guess my next purchase WON'T be another Found On Road DEAD...
I know there's going to be mixed opinions with people. I've been driving SD trucks since 2000. I've had a 1999 V10, 2004 6.0L, 2006 6.0L, 2010 6.4L, 2015 6.7L, and now a 2022 6.7L.
There's never been a year built that's NEVER had a problem or possibility of a problem. Why have I stayed with Ford?? Better the devil you know than the devil you don't.....
For me that's knowing the resources we have at hand, the people sharing the information they have learned, and "knowing the devil" in general.
If ANYONE thinks there's greener grass.....go get it. Stop whining.....
Whining??? WTF you think forums like this are for? FYI, sharing info is NOT WHINING...
BTW, GM did supply a loaner for my 2018 truck and it DIDN'T take 4-5 weeks for an "appointment" AND the loaner was a TRUCK and not a car. So, maybe there is MUCH "GREENER" grass than you think....
Very true. I love the way mine drives with my trailer. Does feel a little awkward with no load especially at low speeds. On the bright side if no 7.3's are affected then it should be slighty more managable for Ford to deal with hopefully making it easier for those affected.
Mine is DEFINITELY effected and it has 7.3. I'll update what was done.
You haven't said anything that hasn't already been said by plenty before you. You can't get blood from a stone. Ford appointments are like that everywhere right now. We know what it's really like....
Listen I wish I could be closer to people that are experiencing these kinds of transmission shifting issues. I just want to see/feel what they are experiencing. Why? Not to call someone out, I want to understand the problem/symptoms myself. It might be a learning experience for me, but then it might be a learning experience for the driver.
When you dip out to "those other guys" please let us know. Good luck.
What issue do you have with yours? The 7.3 likes to drive under load. When it's empty, the shifting is a little awkward almost like it's looking for the next gear.
That's how my issues began. It WILL get worse eventually. If you're lucky they'll actually consider it UNSAFE to drive as they'll should and issue the recall and you won't need to wait over a month before diagnosis to get a loaner.
You don't need to reply as I don't bother or waste ANY of my time reading your STUPID POSTS...
Hey Guys, was on the phone with ford canada and my local Alberta Dealer. I have a 7.3 2020 in the specified date range. Both confirmed that I am unaffected according to the data they have access to. Also, this CSP isn't even a thing in Canada. Fingers are crossed regardless. I had the torque converter replaced per a previous TSB and since then it has been perfect. Don't even feel the tranny shift other than an occasional downshift jerk (fairly gentle) at low speeds creeping through the neighborhood but from what I understand that is "normal" behavior for these trucks.
What tsb did you have the torque converter replaced. I know of the one and my production date falls within it. But, never got a notice and doesn't come up in Vin search.
Thanks
I just got my truck back (July 14th), got the recall notice and made the appointment (June 5th) for the "simple fix". They opened the transmission up and determined that the whole unit should be replaced. Six weeks and 4 loaner cars later it's fixed. I have to mention that the Caruso Ford Service (Long Beach, CA) people did treat me nice, were very attentive to my questions.
I haul my 5th wheel and never noticed any harsh shifting, late shifting, grinding, or anything on the original transmission. My truck has 38.5K miles, so I was surprised that it was a total replacement. Well its done and I'm going up in the mountains to shake it out.
Brought mine from Vegas to Mesquite in hopes of fixing my POS trans that has ALL the symptoms and then some as described under the tsb or csp or whatever ford is trying to call it. 7.3 with 4.30 rear that SUCKS DOG SHIT...AND VERY UNSAFE TO DRIVE!!!
Even though they(Mesquite Ford) scheduled me for an appointment a week ago knowing full well as I told them it was for trans. They told me 8/15 was earliest date to drop off...
Told them I'm going to Texas for 2 weeks and maybe they could possibly diagnose(squeeze) my truck in. Was told the diagnosis was to drop the pan and see if metal is present. If so, new transmission needs to be ordered. If not they do the BS partial rebuild.
Well, considering how fcked up mine is there's DEFINITELY metal and new trans should be in order soon.
One would think the vehicles that are being presenting with the symptoms should be priority as a VERY CONCERNING SAFETY ISSUE and not the ones running ok???
Anyhow, thanks for posting your experience going through this recall??? Or whatever Ford is trying to call something that could possibly KILL someone....RECALL THE DAMN THING BEFORE MAJOR LAWSUITS ARISE!!!
Hopefully they're able to do the "right thing" and check it out....SOON
Minimal towing with it. Maybe a bit more city driving than highway though could have encouraged the FAILURES???
Ford will probably always do what financially benefits them. If a wrongful death lawsuit is cheaper than a recall they will let you die. They've done it before.
Back from Texas and Truck back home. Dealer replaced CDF assembly. There's a TSB on it (paperwork in truck), I'll post the exact # if it's on there. After reading a bit looks like there's a redesigned version now which hopefully was used for my replacement that has a "lip" machined in the hub to prevent it from slipping.
GOOD LUCK with your repairs if under warranty you know what to do....MAKE AN APPOINTMENT at first sign of malfunction as it WILL only get worse and could cause accidents.
Thanks to the people at Ken Garff Ford Mesquite, NV. for fixing my truck.
TSB 23-2160 https://www.tsbsearch.com/Ford/23-2160
Symptoms are more than just loss of 10th gear from reading my previous posts. It's the stuck in 10th after coming to stop that is the dangerous part Ford should issue recall for and get all these affected trucks with the 10R140 transmissions with "old" style CDF in them repaired regardless of mileage and if out of warranty.
