2020 F250, Single piece axle.
--Last year I did
BDS 5" 4 Link Kit
Leveled the truck out, rides nice... But with 1000lbs on the hitch, it dropped the rear significantly.
(Net lift is 3" vs stock F250 vs Tremor which has a 2" lift stock).
--I added the Road Active Suspension kit, keeps the truck 97% level. (Love this setup, have had it on a few trucks).
Also could be my OCD about it not being 100% level when towing.
--Added the ReadyLift 5" Tapered Blocks, got my rake back (its not as noticeable as the original rake, but its there).
--Added the BDS Recoil traction bars (because they look cool, and I wanted to avoid any chance of axle wrap) and I had a slight concern about the mounting position of the blocks (over concerned at the time of purchase, turned out my OCD got the best of me).
I don't have a current pic of the truck and won't be able to get one for a few weeks as my brother has it while he is moving. I do have the pic before the ReadyLift Blocks and traction bars, you can see the truck sits level. Pic has old tires, 35x12.50R20, now have 37x12.50R20, fills it out a bit better, but gonna go 13.50's the next time around.
NOTE: the BDS 4" rear blocks are 4.5", no taper. I didn't get any vibrations. The ReadyLift blocks are exactly 5", and tapered. They do move the axle forward about 3/4-1" due to the taper/pin placement. No vibrations, axle shaft input depth into the transfer case is much closer to stock, where the BDS flat blocks pulled the driveshaft out about an inch.
If you go the BDS kit route, wait for Black Friday, I saved $600 in doing so last year.
BDS kit was an easy install, in my driveway in one day.
