- Jun 25, 2020
- 6,439
- 10,901
- >>US Army<<
- Is she DAF or just ignoring me??
- 2022 F350 CCLB (11/2022)
- 2015 F350 CCLB 225k // 2006 F350 CCLB 280k
Haven't been in an area similar to see but it didn't matter which lane I was in on the highway. I found it was the least obnoxious in the left lane, I assume due to the crown of the road.
Would be interesting to see how it does if there no lane markers since I assume it uses those to self correct
Don't let roadway "crown" or "pull/push" make you go crazy. Yes, it happens, but there's a simple way to check the truck. Be safe with the procedure below.
Big picture on a flat parking lot :
If at any point the truck tracks straight with the steering wheel off center it's an easy fix.
If the steering wheel "holds" off center AND makes the truck turn either direction it's a bigger problem.
A parking lot tends to be a bit more flat versus a typical roadway. I like to "test" the steering holding/tracking on a nice huge wide open parking lot. Align the wheel, drive forward slowly (it doesn't take much) watch the steering wheel.
IF the steering strays off....how bad?? Does it track like you are turning the wheel for a turn or does it stop at some point??
Testing for return-to-center (RTC) : Start with the steering wheel centered. Drive forward, turn the steering full lock in one direction (count number of turns estimate on a partial turn if found like 1/2, 1/4 etc etc). Release the steering wheel while still moving forward, steering wheel should RTC (almost 100%, maybe REALLY close but not back to 12 o'clock).
Now center the steering back to 12 o'clock (remember the number of turns from the other side), with the vehicle moving forward turn the steering wheel in the opposite direction counting the number of turns. Moving forward release the steering wheel to RTC, see where the steering wheel ends up.
Results/findings : Compare the number of turns for each side. If that number is the same, good deal. If it's a little off....could be just the way it is setup. If there's a huge difference (1/2 turn or more) you need to fix that first likely a little adjustment you can do in the driveway to "center" the steering wheel.
Owner induced problems : Bigger tires, wider wheels, lift kits can make this seem like you have HUGE issues, it's not really the case all the time. I think wheels/tires make a return-to-center more difficult to be 100% accurate. It can give a false positive failure by not RTC, as I said "close enough" can be like a steering wheel turn of an 1/8 or 1/16 of a turn to get center. I'd say that much additional turn to RTC by the driver is normal for "larger wheels/tires/greater offset over OEM specs".
Don't waste too much time waiting on a dealership. It's not hard to spend 20-30 minutes to drive to a large parking lot to see for yourself.
