2020, 7.3, dual battery / alternator.
So for the last week or two I started to notice the truck starting slower and slower, not yet to the point where I thought oh no will it not start this time, but noticeably slower than normal. Came out on Monday morning and turned on one of my radios that has a voltage gauge and its sitting below 12v, something like 11.68. Open the hood, the drivers side battery the eye is dark, passenger side battery the eye is showing green. I figure that being 4 years old and hearing all the horror stories about the factory batteries that the drivers side one must be going bad, and its pulling the passenger side down as they try to equalize when the truck is off.
So, get two new batteries and go to change them tonight. I make note of the voltage before I disconnect the drivers side, thinking that it will go up when the "load" of the dying battery is removed from the good battery, but when I disconnect it the voltage actually goes down. I replace the drivers side battery first, then move on to the passenger side. The passenger side battery looks like there is some moisture on the top, like it leaked out a little bit but not too much, otherwise visually everything looks fine before I take it out. When I remove the positive lead there is a pretty good amount of corrosion inside the battery clamp that was not really visible before it was taken apart, this post is on the half of the battery with the moisture on it.
Clean up the battery clamp really good, install second battery and spray all of the posts with the anti-corrosion spray.
With both factory batteries both out and in the garage now they are both reading around 12.5 volts.
So what the heck is going on? Could the corrosion cause what was happening? How does corrosion on the passenger battery make the drivers look low and drag the whole system down?
I have a dash cam that is always powered, it connects to the drivers side battery. My understanding is that both batteries are linked together like one big battery so if that is correct it would technically be powered by both at the same time, so it would not just be draining the drivers side although the amount of power is uses must be quite small. Nothing else it powered when the truck is off and parked.
