Slow starting and battery replacement leads to confusion...
What adapter are you using? I tried to find one, the one I found on amazon would not work on the ford trucks.
This is the one I use: https://www.amazon.com/dp/B0049MVDZG?ref=ppx_yo2ov_dt_b_fed_asin_title
I set up a trailer called "Cooler" and set it up with the minimums (literally think the length is 3') so that BLIS would still work and not get the "trailer connected, Not set, BLIS disabled" warning. You can run it without it as well
Thanks, will give it a shot. I guess the computer does not send power unless it thinks a trailer is connected and the last one I tried was not able to trick the computer.
I ordered a hardwire kit from ARB that should be here today that I plan to try an install. I want to try and test a theory that the trailer BMS system varies and changes voltage. Plus that 5th wheel plug will lose power after turning off the truck. I want the cooler to stay on (havent decided if I am using the #5 or #6 upfitter or going straight to the battery; either way the cooler has a battery saver that you can adjust thresholds for it depowering. I might eventually get a small jackery to run inline later.
Post up how it goes and what you do, would be interested to see it!
