S&B 60-68 Gallon diesel tank update
Do either Long Range America or Titan offer the calibration module to handle 23+ DTE issues or would it depend on the S&B module?
Just an update on this, Aiden - one of the co-owners of Long Range America - reached out and advised that his filled-up his Super Duty at high-flow pumps and hasn't had an issue.
who makes this, that sounds cool as shit. Not that i need an add'l 10 gallons
This is on the product roadmap for Long Range America. It sounded like it could be released this year.
The S&B module is the only option for getting DTE to read "correctly" with the aftermarket fuel tank.
There are several place can make it work using the FRDS tool, Tugboat had his done at a dealer and the guy (independent shop) that will do mine if the ever get the fast fill revised says they have no issues getting DTE to work correctly.
Ok... So had a great discussion with one of the owners of Long Range America. Their 60-gallon fuel tank does not work at high flow diesel pumps. The issue is the size of the vent tube and needing a significantly larger one to accommodate the rate of air displacement that occurs when using a high flow pump. As their 60-gallon tank is a recent release, a redesign is not on the horizon as it would require re-engineering a few aspects of the tank (in addition to the filler tube) and getting the redesigned tank DOT certified.
If high flow fuel pump compatibility is your top concern, then waiting for the S&B update is going to be your best bet.
I will say, after seening the Long Range America tank first hand, it is a very well designed and built product. It has the same depth as the OEM plastic tank and has a built in sump location so that you can maximize fuel utilization.
We're working with the team at Long Range America to see about a discount for forum members, so stay tuned for more on that as we pull that together.
I have the LRA tank coming for my GX. Great products, but pricey. Not any competition for them on most platforms so they can basically charge whatever. Can’t wait to get mine.
so how many fill-ups does it take to hit ROI on purchasing this unit?
You're in California. Based on your fuel prices, I don't think there's a number where you reach an ROI :ROFLMAO:
In all seriousness, getting the 58-gallon gas tank for my truck was a game changer for road trips. On pure highway driving, I'm looking at 600 miles before I need to fill-up, and under the best mpg I get with my current set-up can get closer to 700 (with true DTE = 725). This allows me to focus on getting gas at Sam's Club or Costco where the prices are better than most other stations.
The consideration is really more how far do you want to drive before you have to fill-up? If cutting your trips to a gas station by about 45% is meaningful to you, the ROI is immediate. If getting gas is convenient and you don't really go on long road trips often, then you won't get as much benefit from the larger tank.
33 gallons in the bed. 67 gallons total. My local truck store has one of these. I'm thinking of one simply because I can remove it if I trade in. It only adds 280-300 lbs to my bed. I'm still well within pin weight. It wont get in the way of my 5th wheel hitch. Fits well below my bed cover with space on top to spare. I know some here need the bed space, so I can defiantly see the replacement frame tanks in those cases.
https://www.campingworld.com/rds-33--gallon-auxiliary-diesel-fuel-tank-72929.html
thats cool, id be worried about fuel smell/expansion from heat cycling under a closed bedcover and making my suitcases smell like diesel fuel. Good way for my wife to hate me, a lot we travel in my truck instead of her wrangler (for all the obvious reasons lol).
I travel from AZ to CA and back often and will be nice to fill up on the cheap side of the river and get in and out of CA without having to fuel so I'd think 3-4 trips would net an ROI.
Its not all about ROI on a mod like this and more about convenience.
What is the ROI on a lift kit and 37's?
this, think about fighting to the front of the pack on a long drive to have to pull over refuel, then get back in the race and have to repass everyone you fought an hour ago :-D
yeah, but by the time you fill-up, the race is over LOL
Good point. No matter how awesome the smell of diesel and grease is. My bride would definitely give me hell for that.
My reasoning is when pulling the trailer I get 10mpg so realistically have a range of probably 250-275 miles max so if your off the interstate at all that gets concerning to me. Plus the benefits of buying when fuels cheaper.
@mrmag00 is quite right the convenience of not having to look for fuel in the middle of nowhere with 200-250 mile range towing is called stress relief. 🤪
At highway speed on 37's @9500lbs average mpg is 16.8 - easy 700 mile range,.
At my age bio break need come well before needing fuel 😁
Anyone know whether S&B is still going to update their tank/filler neck so you can fill at the high flow pumps? At one point someone said it would be this summer but I've not seen anything official.
