Arrived today, DTE module
I know from S&B on the pre module trucks like the 23s you're only changing capacity and no adjustment for the float arm scale is made. I am curious if S&B is doing that with the trucks calling for the module...iDash is taking it's info from CAN bus which should reflect signal for fuel level, at least that's what my research says, of course like you can really trust the internet
I have not set up my iDash to look at fuel quantity yet am monitoring EGT IAT Charge Air Temp and vane position.
@JTredway, don't know if I'm addressing your question, have noticed with fuel gauge, that 60gal tank changes the scale at bit taking a long time to come off the full mark yet when reading 3/4 full filling up takes 44-45 gallons,
@TremorSS at 0 DTE with less than 1/8 tank indicated on fuel gauge fill up with 55 gallons which indicates Ford is using a 5 gallon reserve when calculating DTE as am not using S&B module.
“Only 400 miles after half” is still crazy thoughI know from S&B on the pre module trucks like the 23s you're only changing capacity and no adjustment for the float arm scale is made. I am curious if S&B is doing that with the trucks calling for the module...
Small potatoes for guys like me just misleading to see like 200miles happen before it ever comes off full and like 600 miles before half and then only like 400 miles after half![]()
it is comical, especially when i have people ride in the truck and dont know, they look at the cluster and see like ~500mi DTE and i am like half a tank and they go wtf“Only 400 miles after half” is still crazy though
One dealer refused to warranty my sender out bc they just said no due to fuel tank. Called another dealer and they said the tank didn't cause it, bring it inDoes installing this tank does void any factory Ford warranty?
So if I read this correctly, the tank will not require replacement, just the filler neck? I’ve been holding off on a purchase because I want the fast fill integration.Talked with Marco again at S&B customer service he said the “fast flow filler neck” that they talked about at SEMA is set to release sometime in June.
Has anyone heard any new about an updated fast flow filler neck? I was thinking about buying one but guess I'll wait if it's still going to happen this summer.Talked with Marco again at S&B customer service he said the “fast flow filler neck” that they talked about at SEMA is set to release sometime in June.
