Rubber style bed mats
I use the rough country mat.
It's cheap, doesn't look too terrible, holds stuff in place, and is super thick and heavy so good impact protection.
I second @M4X - Rough Country works great. lower price, very thick and heavy so it doesn’t move, protects the bed well when throwing heavy things in the back. Very happy with the purchase.
That's the one I have considered. The FAQ's on the Rough Country site say that it won't fit correctly with spray in bedliner, do either of you have the spray in liner with that mat?
Yessir I have a TOFF spray in liner. Works just fine.
(It looks a little curled up on the edge in this pic because it was still new. Few afternoons in the sun and she layed flat.)
I have the ford one on top of my line x. I really like it. keeps things from slidping around.
I also have the factory spray-in liner with the Husky mat over it. Helps with objects sliding and prevents dents in floor of the bed. Easy to pull out and wash when we take in on vacation and don't want deer blood and mud back there.
This is going to sound a little rude, I apologize. What's the purpose for the Bed Mat ...?? There are such a variety of mats, for just as many uses. Custom fit Tray style mats come in hard or soft plastic, Exact fit Carpet kits like Bed Rugs, or universal roll up rubber mats. The list is endless.
I get what you’re saying. I have the ford rubber bed mat over the factory spray in bed liner. I have done this on all my trucks. I have a rubber mat to keep stuff from sliding around. I also use it to protect the bed from dents from rocks, firewood, etc.
I have the Rough Country rubber mat. I cut holes for the 5th wheel prep package. I do have the factory spray in bed liner. So much easier on the knees when hooking up the gooseneck. To me, it works and fits great.
I do like having the rubber mat, even with the spray in liner. It's a lot easier if you have to kneel down.
Same. Plus if you haul a lot of dirty stuff, it's easier to pull it out onto the driveway to rinse it off an scrub it than the clean the nooks and crannies of the spray in liner.
I have this also
Big R or Tractor supply "stall mats" when I want a tough barrier. They are inexpensive. The Rhino lining spray in the truck has plenty of grip, I have not had the need for a mat to keep things from sliding.
@Motoxxx43 I had a Rhino lining in a previous truck and loved it. It was a much softer material than Line-X or the factory spray-in. Agree, I never felt the need to have an additional mat with that...
How does this mat work with say, sliding a loaded cooler or a fire pit with metal legs? Does the material bind up?
I have a 40-quart Engle cooler (similar to Yeti, less expensive) and slides in and out just fine, but at the same time, the rubber is somewhat grippy to keep things from sliding around. The "rubber" (PU) is very stiff and durable, does not bind or fold when sliding things across it. It has a dense moulded foam backing which fits into the grooves on the bed and tailgate and with the spray in liner from Ford and Velcro kit included with the mat, it does not move in the bed.
This mat is not easily removable since it sits so solid on the bed with the Velcro, it holds very well, but if I need to remove it, it's possible. The Velcro actually sticks to the Ford spray in lining when installed per the instructions, though I have not tried to remove it yet. I'll know if/when that time comes. 😑I guess you could also opt to not use the Velcro in the bed but required to stay on the tailgate. The mesh screen may also move a bit if you do not anchor the bed side, at least at the trailing edge, though there is no sewn in Velcro patch on the liner at the tail edge. (You would have to improvise.)
My truck has the spray in liner but I picked up a Ford rubber one too.
The spray in doesn't really hold equipment in place. I like that feature in the rubber mat.
Not a fitted bed mat but if you want heavy duty protection check out Stall mats from Tractor Supply. They are heavy, chemical, oil, fuel resistant. Get 2 and cut to fit. There will be seams but if you cut precisely they fit tight and will not move. 3/4 inch thick and about $60 each.
