- Oct 4, 2022
- 1,218
- 2,006
- 2022 F350 Tremor w/ 50Ten Camper
- 2025 F150 5.0L.
Install looks great, and the output on those LP4s is inane.The Baja Design LP4s have been installed. It was a long day, and it actually started yesterday afternoon. I went ahead and installed the SDHQ mounting brackets on my 2024 F350. The instructions were good, but not perfect. I also watched the YouYube video of a fellow forum member (@DIYRay), which helped a lot.
The first issue I ran into was that the attachment to the SDHQ mounting bracket (driver's side only) actually attached in a way that it touched the windshield when I tightened things down. That was a big NO to deal with. I reseated everything, but ended up with the same situation that when tightening things down it would touch the windshield and I was concerned about a pressure crack of the windshield. I decided to pull the attachment off and used an angle grinder to adjust it to my needs. That seemed to work and so I installed both mounting brackets and attachments on Friday afternoon/evening. I cleaned up everything ready to continue with the Baja Designs LP4 install on Saturday morning.
When I opened the hood on Saturday morning it made a loud bang kinda noise. When I investigated it turned out to be the hood scratching/rubbing on the area of the SDHQ bracket where the logo and the flag are displayed on the bracket. I took everything off and re-adjusted a few times, but while it cleared the windshield, it did not clear the hood. When I closed the hood on Friday night it already rubbed, but I also never opened the hood for testing once I had adjusted the attachment bracket.
After a couple more tries I got the angle grinder out again and removed the portion of the SDHQ mounting bracket that hit the hood. I finally had it all working and so moved on to install the BD LP4 lights. That was a non-event and then I build my own wiring harness as the Baja lights came without one. Overall, this went well, even though I had to remove the windshield wipers and the plastic cover at the outer hood area a few times to feed my cables and the Deutsch connector through.
I used 12 gauge wires, routed the cables to near the upfitter switch fuse box and then merged the cables from the left and right lights into one before connecting it to the upfitter switch #1 wire for power and attached the ground cable appropriately. In between I tested the lights and wiring and this all worked as expected.
During daylight the LP4 lights from Baja Design were already impressive, but when I went outside when it was almost fully dark - holy cow. Those LP4s mean serious business.
I was surprised and then not surprised about the SDHQ mounting brackets (drivers side) and that it was not a 100% fit. We're talking fractions of an inch or better - millimeters here. It really slowed me down and I still have to apply primer and pain to the main area where I shaved metal off to get this to work, but it was a warm day and I am fully exposed to the sun in my driveway that I decided to do that tomorrow.
When I checked out the lights this evening at 90%-95% darkness - holy cow. I can only imagine what "damage" LP6 or LP9 would do. My LP4s put out significantly more light compared to the Morimoto 4Bangers that I had I at my 2022 F250 Tremor.
We let SDHQ know about your bracket dilemma and hope to get a resolution soon.
Im glad we were able to take care of you with the brackets and Baja LP4. If anyone else is looking to run something similar, reach out! We can hook you up with a forum discount!
