Recall: Loose/Sagging Underbody Insulator - 7.3 gassers Drive shaft - Diesel Beast not effected
I just crawled under my truck and only saw one piece of insulation near the front barely over the driveshaft and it appears to be adheard to the body and has the plastic pins. I didn't see any over the gas tank so maybe my truck isn't affected by this. My build date is Jan 22, 2021.
I got the recal, mine build was aug 2020. I just did exactly what you did and saw the same thing on mine. Nothing anywhere near my super special driveshaft
"Ford says in documents posted by the National Highway Traffic Safety Administration that heat and noise insulators below the body can loosen, and touch the drive shaft. The shaft can fracture, causing a power loss, or loss of control if it hits the ground."
Soooooo - sounds like something like a heat shield comes loose and starts rubbing the drive shaft - I have a feeling any diligent owner would notice should a rubbing sound on the driveshaft. I wonder what exactly comes loose??
Think your dealer would fix my sagging “underbelly “ and other saggy parts🤪🤪🤪🤣🤣
Ask me again on April 1st and I'll let you know if they took me into the shop as well! :ROFLMAO:
Under the body, above the rear of transfer case and front end of driveshaft is a thin aluminum insulated heat shield that is sticky backed to under body and a couple plastic push pins, that can become unstuck and droop down onto driveshaft.
Crawled under mine after first week home last October and the underbody insulation was hanging down and had rubbed the driveshaft. Adhesive backing, guess it was new enough not much dirt on it yet pushed it back up been there every since. Appeared not any pressure was applied on install.
This recall just highlights why doing your own oil changes and going over the underside of the truck with a fine tooth comb every oil change is a great idea. Will definitely be pretty lame if it's just because someone didn't push it on positively enough.
I knew someone with an F150 and that thing did have a pile of heat shield falling off type issues....
So what is the fix here? Sounds like they are just looking at the heat shield/insulation and securing it if sagging? Hard to imagine it hurting the driveshaft but I guess over time it could weaken it?
Yes that's exactly it - it seems the shields riding on the rotating driveshaft is scoring the driveshaft. When you have a score around the outer diameter like that it creates a potential stress point and with the applied rotational torque it can fracture and catastrophically fail. Funny how a seemingly fairly innocent thing can escalate like that huh...
Seems like you could just look under your truck and see if its sagging, dont really want to deal with the shop on this if they are just going to look at it then send you on your way. Weird recall, not sure I have ever heard of anything so minor. Also didnt realize its an aluminum driveshaft, not sure Ive ever had a truck with that. Assume if the heat shield falls on the diesel steel driveshaft its acceptable lol.
After seeing this recall brought up here I called my dealer. They were able to get me in yesterday due to some previous cancellations. Dropped it off at 1030 and by 1230 it was finished. No damage and they added 2 rivets per the tech notes. Pretty painless.
Checked mine early this morning. Mine was slightly loose at the rear edge of the insulation, but was attached in several locations with the plastic push fasteners with about a 1" diameter head. Overall it looks very secure and no where near my drive shaft or wiring. I think I'll do the 3-M adhesive thing along the back edge and just keep and eye on it over time.
