Recall: Loose/Sagging Underbody Insulator - 7.3 gassers Drive shaft - Diesel Beast not effected
Checked mine, 19000 miles and not loose at all. Early 2021 F250 Lariat.
Any reason I should take the time to have it checked out by the local Ford dealership anyway?
After seeing this recall brought up here I called my dealer. They were able to get me in yesterday due to some previous cancellations. Dropped it off at 1030 and by 1230 it was finished. No damage and they added 2 rivets per the tech notes. Pretty painless.
Same fix for me today on my 21 F250 Tremor. Attached is the technician note ref same.
As others are reporting, and based on what my dealer told me, they'll reinforce how it's attached. So it's not purely an inspection. That seems worth it to me to make sure it doesn't come loose down the road.
Are they drilling directly into the floorboard? Are the floors of the cab aluminum like the bed?
Just thinking road salt up north here and exposed metal where the hole was drilled.
Can one of you guys take a picture of where the rivets are installed? My dealer is an hour away. I would much rather crawl under there and take care of it myself than spend half a day driving and waiting.
Alternatively, you're getting the short end of the stick and your driveshaft will eventually be cut 150,000 miles down the road. :ROFLMAO:
My shaft aint gunna get anywhere near anything thats gunna cut it. Once, in it's early days was enough. Anything after that, good frik'n luck gett'n close .. 😂😂😂 ..!!
On a whim decided to check for recalls on my truck (adding that to my oil change process) and turns out there is one! Issued February 16, 2022, so quite new.
I can't find any details on which specific years and models it applies to, but you can look up recalls for your specific truck here:
Seems like it should be a pretty easy fix if it's done before any driveshaft damage happens, but experience will tell obviously.
Here's the text of the recall, and a screenshot is attached:
I crawled under today while I was installing a Banks diff cover and my 2022 7.3 Tremor has no such insulator.
Same here. Jan 2022 build. No insulation.
My mid-Dec. 2021 build appears to have had the insulation removed. Still plenty of adhesive residue left. Must be why mine does not appear on any of the recall lists.
I was thinking about doing sound insulation on all of the un-insulated underbody areas but must seriously reevaluate now.
Attached is an annotated pic of existing keepers and newly installed rivets on my 21 F250. Previously posted a copy of the technician note indicating he drilled two holes and installed two rivets.
"... Ford noted to the NHTSA that it removed the problematic insulators (part numbers HCB-2611130-AB and HC3B-2811130-AB) from production on December 10, 2021. Trucks built at the Kentucky Truck Plant after that date have a new under-carpet thermal patch instead."
Nice
