Finally got the 2019 limited 350 over for a test fit. Brackets were easy to bolt up, but there is not a ton of extra length left on the bolt after the bracket is on. Could not figure out a way to accurately measure if a spacer would fit as discussed earlier.
I bolted these up bracket face to the rear instead of front, couldn’t discern much difference in mounting things either way as the edges are equidistant, so that’s how I did them. The bracket fit very nicely into the recessed part of the rear bumper where the t40 bolts reside, so width-wise I like the form factor. Length seems good as well for all the lights I’ve used so far, but I think the bracket needs to be taller. Once it’s bolted up to the bumper in the leveled position, there is about 3/4“ on the inside from the bottom of the bumper to the bottom of the bracket, while there is a bit over an inch on the outside of the bracket from the bottom of the bumper to the bottom of the bracket. I don’t think there is enough room under the bumper with the short height of the exposed bracket to directly bolt a BD S2 bracket to this bracket and have the light face vertical. This however, was my eyeball assessment, as the current S2’s on the truck were a pain to get bolted into the truck, so I did not disassemble them to try them in bracket.
Also, the bolts supplied with the S2’s are bigger than the holes in the bracket. My rough measurements put the hole at .316 of an inch, while the S2 bolts measured in at roughly .345 of an inch.
When bolted up to the drivers side with both bolts, passenger side is great, while the driver side bracket will most assuredly impinge on an Amp step if so equipped.
All that being said, I like the bracket better then anything else I have seen for this spot. It can be bolted more inboard using just one of the t40 bolts instead of both, which will provide more room. Also, have you given thought to perhaps elongating the two bolt holes for the t40s? Simple design change, but it could provide more mounting flexibility side to side. If you haven’t yet, it might be beneficial to look at the most common lights on the market to determine the size of their mounting bolts and determine the optimal size for the production version. Nothing that a step bit or die grinder can’t fix for outlier sizes though.
View attachment 107581View attachment 107582View attachment 107583View attachment 107584View attachment 107585View attachment 107586View attachment 107587
