Rear Bumper Light Bracket R&D: Coming Soon!
Want to buy the brackets when they are launched? (Assuming price is within your budget)
  • Yes - I’d buy them
    Votes: 26 78.8%
  • No - prefer a different product
    Votes: 6 18.2%
  • No - not installing rear lights
    Votes: 1 3.0%
  • Total voters
    33
Just to be clear, will he know you are doing the test?? 👀😂
Yes, he also needs me to do some forscan changes for him so I'll get both done in one trip.
Might be more fun to try without him knowing though. 🤔🤣
Hey everyone! 👋
I’ve been doing some Tremor R&D by designing a bracket that you can use to hang LEDs (or other things) under the rear bumper. No drilling required!
The truck has 2 bolts on each side of the bottom of the factory bumper. These bolts hold my bracket to the truck.
I’ve completed my 3D models and 3D printed some test parts that I’ve used to confirm fit on my 2022 super duty.
I’m looking for volunteers to test the fit on other year super duties. If you test the bracket and send me some photos of the fit, I’ll thank you by sending you a full production aluminum version for free when they are available! I’m hoping to launch these for sale in early 2023!
I’m looking for 2 volunteers per model year. You do not need to hang lights for the test… just ensure the bracket fit to your bumper is correct. Thanks!! 😃
Here’s some photos on my truck with an earlier design but still the same concept.
View attachment 106319View attachment 106320View attachment 106321
I have a 22 f250 platinum with the rear step. I'd like to be considered to be a tester
Happy to have you try a set too since you’ll be testing rough country lights.
Will be interested in how the testing goes with Amp Step as I have one and not seeing how it will work :unsure:
2021 non-Tremor if it helps
Absolutely no way the light will work with the AMP bed step, if you have a bed step, like me, the best course of action is to mount the light elsewhere, you can see my test spots for now.
Funny you say that because it will work with the AMP step. I contributed to the project.
Interesting. Show me a photo. I measured this weekend and there was no way to mount the light on the bolts without them bumping against the step. Even in Legmar’s 2nd photo above the light is mounted where the step would rest.
I think there is enough room but dependent on adjustability of bracket and the light used I think? Like I said, will be following the testing results.
Also, it's been a bit since I installed the step but seem to recall options for how much the step stuck out or placement on the step itself? Am I remembering this correctly and will it matter?
Here’s a couple tips I can think of…
I think the direction of the bracket that holds the light you’re installing makes a big difference. It’s often reversible. So test it in a couple orientations (up/down) when attaching to the bumper bracket I’m making.
Second, the slots on my bracket can be used to mount a light a bit offset from the center hole. Perhaps that is helpful as well.
Here’s some of the photos that @BroncoHooves provided to me showing the Baja designs S2 light attached with my bracket next to the AMP step.
