If we could get a group buy I would be in for a set all around.
Ditto. I've also read here on the forum that they produce a lot less brake dust which is good for keeping the front wheels more clean.If we could get a group buy I would be in for a set all around.
He handles these?
"Optics" and "brakes" don't mesh but I'll check him out!
That's cool and all but no where on the site does it confirm what you state for the "normal person"
He handles these?
I'd definitely support forum members that are fair. I won't be doing many mods, mostly because of finances and I will be pulling a bass boat most of the time and not off roading. But I will upgrade brakes, install LED headlights, installing LED light bars, and installing the badlands winch i received for Christmas last year. Beyond that, I don't see any other upgrades. Maybe a bed cover later down the road. If there is a forum member that is trustworthy and fair priced, I'd buy everything from them easily.
My question:
Are the stock Tremor Brakes/Rotors the SAME SIZE as the standard F250/F350?
Also, I would assume 22MY will remain the same as 20-21
I'd love some more info about this. Will it work with the 18" wheels? What's bigger about it? How would it compare with this PowerStop option?And we'll be bringing out an actual big brake kit from Alcon at some point in the near future as well.
If I'm going to invest in upgrading brakes, might as well go bigger if possible IMO.
Appreciate it! I'll probably wait for more details on that, then, before taking the plunge on the Powerstop gear.I can't really discuss anything more about the big brake kit other than "it's coming soon".
But I will say that the Alcon kit on the Raptor and F-150 was designed to fit as small as OEM wheels so you can clear the stock 17s even with very high offsets. They max out the rotor size and then have adapter brackets for the larger caliper, but the caliper is where the magic happen. On the Raptor, it's 6-piston front and 4-piston rear. In our testing, it brought the stopping distance down to only 105 ft from 60-0mph and that's with aftermarket wheels and tires that are heavier than stock.
Here's a video we made on the Alcon kit for the Raptors. Again, no details are public on the SD kit yet, but we will have them listed as soon as they're made available.
Alcon Brake Upgrade Test for the Ford F-150 Raptor!
We installed a set of Alcon Brakes front and rear on our 2018 Ford Raptor shop truck and compared them to the factory Ford brakes. We did testing from 60-0 M...youtu.be
Yeah, I need to research various brake options and manufacturers since I haven't really looked into aftermarket mod products in a very long time.I can't really discuss anything more about the big brake kit other than "it's coming soon".
I do believe they protect me all the time. ????I think it may have been the St. Benedict Medals.
I haven't replaced Rotors, but I can see where Drilled or Vented rotors would help to dissipate heat. How much in everyday Stop and Go, idk ..That video above is what I want to see. I just cant see the Power Stop kit adding too much braking as it is just pads and rotors. I would like to see a 60-0 test with that kit. The Alcon kit is new calipers with more pistons which should increase the stopping power.
Any further info on this?Wilwood does have a BBK for this trucks, but it requires 20" wheels.
Alcon currently makes a BBK setup for the F450/F550 trucks. It started as a special edition for some fully armored F550 chassis builds, but now they're regularly available.
Alcon BBK is incoming for the F-250/F-350 SRW trucks. I'll have more info to y'all as soon as it's available.
