Phone holders, What are yall using?
I've got a Mob Armor magnetic mount. the magnets are super strong and phone always stays in place. few years ago I took my raptor down to baja for a raptor run and my phone stayed in place on the Mobmatic mount the whole time. I'll definitely be getting one for my tremor when it arrives.
View attachment 24529View attachment 24530
RokForm phone cover with magnet and the vent mount with magnet. They offer many options.
I have used RokForm professionally for five years and never had a phone come off while traveling 50-60k miles a year.
Easy to quickly set or pull phone from and spin if landscape mode is needed.
Love the Rokform system. Use the quad lock with magnet on the mtb and the Harley with zero concerns about it coming unhooked. Genuine solid as a rock. Used magnet only on my previous truck and it to was quite solid… Only reason I’m not using it in this truck is I got a new phone that does wireless charging at home, so I got a different compatible case for that. Just switch into the Rokform case while on a bike, since I’m not riding daily anymore.
Damn this thread…. So I upgraded, the useless wireless charging pad gave me errors cause the case on the phone, and CarPlay has too much issues with phone call quality that the straight Bluetooth connection doesn’t. So I have the phone mount for day to day, and the iPad mount for navigation on road trips. All 67 Designs parts, and dropped the cable from the MagSafe charger through the dash and into the charging pocket from behind, with enough slack to still open and close the sliding lid.
scotch makes magnetic mounts you can suction or stick to a flat spot on your dash. you put a thin magnetic card in the phone case and then stick the mount where you want it and it grabs it. i stuck mine in between the radio preset buttons and the climate control on that angled part.
I went the way of the BuiltRight mount and 67 Designs holder with plans to add holders for GPS and Travel Trailer rear camera monitor in the future. I added a power port up top as well to help with cable management. It’s been in a week and the MagSafe charger has been rock solid.
C352F6E8-A72A-40E0-840E-94287B833E76.webpEB39A6FD-525B-46F4-B9AE-28B4D5C4D821.webp488EBDEC-BC68-4460-B03A-6B606EF66468.webp
I’ve been using a Mob Armor magnetic mount for a number of years now in my current truck. Can’t comment on placement in the Tremor as I don’t have that yet, but can say the mount is great.
Holds the phone without issue over rough forest roads. At worst, particularly if I didn’t have the phone centered well, I’ve had my phone rotate but it’s never fallen off.
Picture shows it just above the radio handset in my F-150. Love it down low. Still easily visible to me, but completely out of my sight lines if I don’t want to look at it. If I need to poke it with my fingers for any reason (obviously try to avoid that) it’s an easy reach.
I'll Second the Mob Armor. I had a proclip and just didn't like the way it sat across the dash. The Builtright is definitely sturdy but looks like it belongs in a tank. with the Mob Armor I just attached a thin metal plate to the back of my phone case and it holds strong even on bumpy roads. My phone case is a battery case so the whole thing weighs about three times what just the phone weighs and it still holds strong. Mob Armor also makes one for tablets so I imagine that one has an extra strong magnet. You can see where I mounted mine and it keeps it at eye level without blocking the vent or obstructing view out of the windshield.
To add to this, I have the Apple leather case for my iPhone 12 Mini and put the plate inside the case, not even attached to the phone or case, and it still holds well!
Obviously won’t work for thicker cases or particularly heavy phones, but it’s a neat option for some. If the plate has direct contact with the mount it’s ridiculously strong.
I used this. Once I found the exact spot I wanted the phone I superglued the ball and socket so it would loosen and fall. Working great so far. It use VHB tape and fits nicely right to the left of the dash pocket on the flat spot. Comes with multiple sets pf steel plates to mount to the phone. I have been down some pretty rough roads and it is holding fine.
i intend to use the wireless charger and wireless carplay.... before i start looking for a mount
https://carlinkitcarplay.com/?gclid...obE4PBz2YioIzrwT8rhjEQpatxKYfr6BoCYiIQAvD_BwE
have it in hand now i just need something to mount it in, longest 2 weeks of my damn life....
Why is this the first post I've managed to see about wireless carplay? Like 100 people have complained about it and for $100 it can be fixed to be wireless? What are the negatives to this (other than Ford should have done this for us)?
There are a bunch of threads about this. I've posted it a handful of times myself.
Negatives of the Carlink:
- It takes a few seconds to boot, but no longer than the truck should idle before shifting to drive anyway.
- It has some quirks when using Siri (disconnects sometimes.) I don't use Siri so it doesn't bother me.
I use this thing with this MagSafe charger: https://www.amazon.com/gp/product/B08HNBHSQV/
Works great. Completely wireless CarPlay and charging. Phone mounted in my field of view so I can use dual screens. Love this setup.
Grabbed a video showing the proclip mount with a wireless charging device holder. I routed the cable into the center console to keep things clean.
Do you think this would fit on the 22's? The dash has a much steeper grade where the mount would sit because of the larger screen.
I added the BuiltRight Dash mount to my 2022 KR and the new screen size does create a steeper grade for the mounting arm. Fortunately it does not seem to cause any issues that I have seen yet, but unfortunately it is not as straight looking as I hoped…
I bought mine from Bulletpoint Mounting Solutions. I love mine. Very similar to the BuiltRight, but it was a few dollars cheaper and I liked the look of this one more . Great thing about these is that you can connect two arms together so that you can have your phone a bit lower than the top of the dash so that it is not impeding your view.
Wireless CarPlay FTW. I find my phone is in my pocket more now. Being an odd one with a front bench, I changed out the cup holder to have an opening to actually hold a phone. When I’m using the full bench, it gets stashed in the cup holders on the transmission tunnel.
