Phone holders, What are yall using?
I went with the Builtright and 67 Designs solution, added a USB port underneath(hardwired to passenger fuse box), and then a MagSafe charger. Phone stays on no issues and charges! Very pleased with the turnout.View attachment 18907View attachment 18906
Where did you get the bracket for the USB and the other port. Do you have a link to the bracket and the MagSafe? Are the 2 USB ports per unit?
Here is what I bought:
Apple MagSafe Charger
Bracket:
USB Outlets - Wired them to the passenger fuse box
Fuse Tap
67 Designs parts
Bracket:
Fuse Tap
67 Designs parts
Thank you
Bracket:
Fuse Tap
67 Designs parts
Do you have the plugs facing towards the Windshield?
I do. The picture i posted of the USB power was before I installed it back and the outlets face the front. I also bought a USB C adapter for the cigarette lighter opening because the Apple Magsafe was only USB C and I didnt want an adapter. You can’t see any of the connectors from the cab. The wire goes thru the mount and is not visible. I can PM you some more pictures if you want. Been using it a couple days now and the whole setup is sturdy and the phone hasn’t budged.
Please
Nice and clean install! I like the idea of having a charging port there to eliminate cords running everywhere. I am going try to copy this. Running power to passenger side fuse panel pretty easy? Still debating between using Ram mounts or the 67 design mounts. Thanks for posting this.
Thanks! Been using it for a bit now and still love it. Took a several hour trip and it was great. Phone stayed right there and charged the whole time. Those magnets are strong.
Running power was a breeze, and much easier than I thought it would be. Once you have the top of the dash open, you can run the wire right down to the fuse panel using the glove box to guide it. There is a screw I used right under opening for the ground.
It has been a couple of months since you did your installation. Have you had any issues with the phone falling off of the MagSafe magnets? 67 Designs says some customers complained about the magnets on the Apple MagSafe charger.
RokForm case with RokForm vent magnet, works flawlessly with minimal hardware
No issues and my phone has never fallen off. Still love the solution. Technically I used the Apple Magsafe mount on top of the 67 design mount and no issues with either.
Michael
Not sure if anyone has mentioned 67 designs. They have great products and a modular design to build what you want.
RokForm phone cover with magnet and the vent mount with magnet. They offer many options.
I have used RokForm professionally for five years and never had a phone come off while traveling 50-60k miles a year.
Easy to quickly set or pull phone from and spin if landscape mode is needed.
I went with BuiltRight Dash Mount and Support Plate, married it with a 67 Design, MagMount G3 and carbon fiber arm in matte finish. It has been a great combination; extremely happy with the setup.
