Partially Locked hub
22WhiteTremor
Tremor Buff
Pennsylvania
2022 F250 CrewCab Tremor 7.3L
After driving 30 miles to work at 70mph I found the drivers side hub was between auto and locked. It’s currently snowing so the roads were wet. As soon as I noticed it I moved it back to auto. Any suggestions or ideas on checking for damage. Seemed to drive normally. I never shifted in to 4wd. Does this need to see professional attention ? If it was a normal diff I’d be less concerned, however with the LS type I’m concerned. Tia
You should be fine since you didn't engage 4WD.
But to be sure, lift a front wheel, try spinning the wheel/axle to see if they move together (locked) or independently (unlocked), listen for grinding, feel for resistance, and inspect the hub for broken plastic/metal; a partial lock means the internal gears aren't fully engaging/disengaging, often requiring manual turning or vacuum pump tests to diagnose if it's the hub's mechanical parts or the vacuum solenoid system causing issues.
Hope this helps and keep us posted. Be safe out in the snow my friend!
Should I be concerned that any of the seals were overheated and I’m going to have leaks
While I don't think driving it for 30 miles should be a cause for concern, I would definitely keep an eye/ear out for leaks.
Hopefully others will chime in soon to offer their personal experiences and properly diagnose the matter.
Here is what our Google friends say.
I agree with Hitfactor.
Maybe try locking them and engaging 4WD and try driving slow off pavement and see if you hear or notice anything.
Just wait till they go out...my driver side was replaced at 60k passengers side was just replaced at 85k....my brake pads have last longer than hubs..🤷‍♂️
Op all you may have done was turn the front axel on your drive. It shouldn't hurt anything....worse case you may have oiled up the seals.
Wouldn't worry about it. It was either locked or unlocked, meaning it may or may not have engaged the axle shaft but it would have just been coasting since the T-case wasn't engaged. You didn't have any load on it. I just had one replaced under warranty because it lunched itself in Auto position and wouldn't unlock. Usually they seize up and fail to lock. Mine completely came apart internally. Made it almost 9k miles.
Zero problem. The other side was not locked, the t case wasn't either. That just means the diff was spinning at wheel speed with 0 torque applied. Also, 0 differential bias since the other hub was open.
Don't give it another thought.
Nah....follow the other posts. Nothing to worry over. Do an inspection, learn for yourself whats good/bad, stop using AI.
Enjoy your truck!!!!!!!!!
I'd just add
if you aren't turning it's fine to engage 4x4 on pavement. just stay straight forward & reverse.
i would engage & disengage in auto to confirm normal operation
both 4h & 4L
same in locked position
if you can hear the clicking it's normal
then watch for leaks at oil change intervals
i wouldn't expect that you damage anything
you would have felt the differential binding especially if it was severe enough to break something
good luck with it🤞🤞🤞
Considering some of the 24 non tremors have a “dummy” lock that stays engaged, I don’t think it would be a concern
I had that happen on my 2024 F350 King Ranch Tremor, only I was feeling it when I turned one way or the other. So I took it in to dealer and they found that my driver side hub dial wasn’t on Auto, just lie you described. They set it to Auto and I haven’t had the problem since. I’ve got 15k now and no problem. Unfortunately it doesn’t snow in Utah anymore so I haven’t been in 4WD to see if drives weird. Agree with others to not worry about it but check every so often that it doesn’t slip out of Auto again.
