Other than Carli........
I'm trying to find that happy medium of on road and off road. But yes - 90+ % of my driving will be pavement.
I appreciate your input.
My happy medium is the Carli 2.5" Backcountry with Deaver Add-a-packs sitting under the factory 1-ton leafs. This setup gives the truck a comfortable ride on and off the road, and allows me to tow at the capacity of the truck. The Full Deaver Progressive leafs, which are typically installed with the Pintop (every option) setups, require airbags (even more $$$), as they reduce the carrying capacity on our trucks to 75% of the stated factory numbers. This makes the rear squat several inches when towing even a moderately heavy trailer and cause your headlights to point up into the sky.
I added Air Lift Ultimate 5000 airbags to mine after the Carli suspension because my truck was sitting level with my 750 lb TW trailer and I was planning to upgrade to a heavier TT in a couple of months. The airbags did NOT improve the empty ride on or off the road, but when adjusted correctly, they make the ride a LOT smoother and controlled when towing my new 9500 TT with a 1350 TW. I adjust my Blue Ox WDH to bring my front back down to 1/4" of the unloaded height, and then I adjust my airbags to provide me with 1" of sag (3/4" of total rake when towing)
If you are not planning to tow heavy, skip the air bags as they all recommend you leave them at 5 psi when unloaded. (even when using the Ultimates which have internal Jounce Bumpers) At 5 psi, they will not provide additional stability, so you would have to keep them aired up all the time.
@KRNIVOR73 - I agree with @Tx-Tremor6.7. Based on your use case, I wouldn't go past the Backcountry kit if you do go the Carli route. Now, if you don't tow near the max, I'd probably add the full leaf spring upgrade along with the torsion bar upgrade. I'll be adding both the Deavers and the torsion bar to my personal truck here soon to get it more compliant on the street.
Happy to go over some options with you to help get a Carli kit dialed in for you. We are a Carli dealer.
So I reached out to the folks at CJC as they really know their stuff on this and I wanted to confirm.
For the basic leveling kit on 17+ trucks, here are the heights for the various model years/trims:
17-19 trucks - 2.5" height increase
2020+ trucks - 3.5" height increase
2020+ Tremor = 2.5" height increase
The end hood height of all three trucks will be identical after the Carli coils are installed.
So the since the tremor only gets 2.5” inches in the front. would I be able to get away without using the add a leaf pack? Because on Carli’s site it says the front will be higher if you do not use the add a pack with the commuter package. But that was for a non tremor getting 3.5”.
There was a member who did just the Carli front coils with stock leafs and the Commuter shocks earlier this year. His truck sat almost completely level.
The Carli site says the tremor only lifts 1.5” with their commuter package coils.
The Carli site says the tremor only lifts 1.5” with their commuter package.
That’s what I thought originally too. But Nick at Apollo ask them. Look at the post I quoted. He says it’s actually 2 1/2 inches. This whole Carli system confuses the hell out of me. I should just convert it over to adjustable coil-overs to make things a lot easier
Their packages all use the same front coils for each engine type, so the only difference between the three is the shocks.
I measured before and after. I got essentially 2 inches of lift up front.
If that’s the case then the rear leaf pack is not needed. That’s good. I don’t want to spend $3,500 or more on the commuter with leaf packs and radius arms.
1st pic is the 2.5” Carli kit (gas) with stock springs in rear. Stance was almost perfectly level. 2nd pic is with Deaver’s installed. It rides much better now, but it is about 1” ass high. They should settle some though.
I guess it depends on the look you're going for. As you raise the front, the rear will lower to some degree. You can see in the pics @Tremor76 posted above. In the first pic, his bad ass looking rig is almost level, which is consistent with what Carli describes on their site when stock leafs remain. In the 2nd pic, the rake is much more pronounced.
1st pic is the 2.5” Carli kit (gas) with stock springs in rear. Stance was almost perfectly level. 2nd pic is with Deaver’s installed. It rides much better now, but it is about 1” ass high. They should settle some though.View attachment 30380
I like the rake in the second picture and it will serve you well when towing.
I may follow your lead and have Dana throw air bags on just in case👍
Just got off the phone with my local shop - He had the opportunity to install the Carli Pintop (EVERY OPTION) on a new F350 Tremor Diesel here in town. I asked him to make sure he drove before and after and provide me with his honest (neutral) review.
He and two of his mechanics drove before and after. He had the following to say:
1. Would not spend the $10k for the system unless I HAD to have that name on my truck
2. Stock rode better than Carli Pintop
3. Ass end is now VERY soft and it feels as though your "drifting"
4. Customer called in to see how to fix - Customer happen to have shop install airbags as well. - Shop recommended using airbags as a "support" to tighten up the ride a bit. Customer has NOT called back yet after that recommendation.
My deduction from this - I'm going to leave stock except for front level so I can fit 37" tires.
Sounds like a shop unfamiliar with the product. The stock suspension on a Tremor in no way rides better than a Carli Pintop. A stock F250 (no tremor with the 2-spring main leaf pack) may take the edge on highway expansion joints but my 250 Tremor with the High Cap Tow literally bounces off the highway in stock form; it's miserable and I commute 100 miles/day.
Ass end of the Carli is definitely softer than stock but nowhere near enough to cause a "drift". Drift isn't a byproduct of spring rate but traction. When I put my 40" Toyo MT on my Ram, I felt like I was driving on ice skates for the first 500 miles. Once the compound firmed up, all way well. I would be willing to bet then "float" he felt had to do with a new wheel/tire setup.
If he had airbags installed, did he do a setup that wouldn't limit travel (airbags with daystar cradle) or just a 4-5" travel double bellow setup paired to his 13" travel rear Carli setup? Perhaps that could've contributed. The shop's directive to inflate the bags is a diagnostic move in the wrong direction. I would tell the customer to call Carli as it's likely something simple either by way of installation error by a shop unfamiliar with the parts, incompatible parts (airbags with Carli), alignment, wheels/tires,etc. Carli would be able to assist far better than the shop by the sound of it.
Thanx for your opinion. I'm searching for these - $10k is a lot to drop when you're doing it blindly. I'm in a place that I have yet to see a Tremor. I'm doing what I can to gather information best I can. You can read all you want online - I don't want to be disappointed.
Thanx for this. To clarify - the customer chose to add airbags at the same time as the Pintop. Shop did not sell them to him. Shop just recommended using them to help offset what customer perceives as softness (Bed completely empty)
You're right in the assuming (Because I did) the most money equates to best ride. I'm trying to find that happy medium of on road and off road. But yes - 90+ % of my driving will be pavement.
Pintop is awesome but much of the time spent tuning the King shocks was in the dirt. This was not a consideration for the Signature Series or Commuter and a lesser consideration on the Backcountry.
Pintop will handle like it's on rails and "round" the sharp edges where the Commuter/Backcountry will absorb these with more of a numb feeling but you'll see a bit more body roll than the pintop and find the bump-stops quicker when you're out in the dirt.
