Funny you mention the caster, I updated my order to the 5.5" system and one of the reasons (other than wifey prefers the 5.5") is that if you look at pictures of both you can visibly tell that the radius arms on the 3.5" system are angled down towards the front of the truck more than they are on the 5.5" system due to the drop brackets. I am sure you already understand this, but that effectively reduces the castor angle at the knuckles. Carlie does provide their castor shims with both systems but the overall number will still be based off of the beginning angle of the radius arms. Of course the reason this is important is that besides front end wear the castor angle plays a large part of whether a truck is susceptible to "death wobble" or not.
With this being said I am quite sure that Carli has that figured out and the supplied castor shims effectively negate the potential issue, but the more relaxed the castor angle the better when talking about death wobble. The other solution of course is their fabricated radius arms that allow for more adjustment to the castor angle, but they are also on a 6-8 month backorder so I did not spec them on my kit. I can understand how the 5.5" system would have more body lean though, the trucks overall CG has been raised by quite a bit with the 5.5" system.
