Other than Carli........
I ordered the 5.5” Pintop with everything except radius arms. Everything was in stock
What is the MINIMUM setup for Carli to handle 37"s with ZERO rubbing at full lock in reverse?
I'm coming from a Raptor. I am use to ridiculously phenomenal off-road at high speed. I want 37"s but I want Raptor Quality ride at high speed.
What should I be looking at? I don't need a tall rig. I just want 37" tires on stock rims to clear without ANY rub at full turn (forward or reverse).
Thanx in advance.
Thanx in advance.
Minimum setup for 37’s and Raptor quality ride at high speed are opposing desires.
The closest you’ll get to a Raptor quality ride in a Tremor (though it still won’t be as good - you’ll need to argue with physics at some point :P) you need to get the full Carli Pintop setup. Front and rear shocks, trackbar, sway bar, full replacement leaf pack, upper and lower steering stabilizers. Then throw the 37’s on at correct pressure and you’ll have the best ride you can in a Super Duty.
Looking at around $10k installed, give or take a thousand or two.
Minimum to fit 37’s is the bare Carli leveling kit. That’s front coils and shocks, nothing else. Will raise the front end up enough to clear 37’s.
Looking at around $1500 for that.
The closest you’ll get to a Raptor quality ride in a Tremor (though it still won’t be as good - you’ll need to argue with physics at some point :p) you need to get the full Carli Pintop setup. Front and rear shocks, trackbar, sway bar, full replacement leaf pack, upper and lower steering stabilizers. Then throw the 37’s on at correct pressure and you’ll have the best ride you can in a Super Duty.
I love the opposing options! Thank You.
Thanx in advance.
You can clear 37s with the Carli 2.5/3” Level. However, the caveat is that the tires cannot be wider than 12.5” and the wheels need to be 9” wide with no more than +6 offset.
You will never get Raptor high speed performance (I have 2x modified Gen 1s), but you can get significantly improved ride and handling qualities.
I suggest you call the guys at CJC Off Road to discuss. They were very accommodating and not pushy at all for the upsell. Explain what you want and they will give you the straight skinny.
Mine with 2.5/3” Pintop below. I had to do some trimming, as I wanted a more aggressive stance and wider tires. (18x9.5 -18 w/ 37x13.5R18).
i suggest you call the guys at CJC Off Road to discuss. They were very accommodating and not pushy at all for the upsell. Explain what you want and they will give you the straight skinny.
Thank you for the input! I'll definitely do just that!
I went Lariat Sport over KR to "absorb" some of the cost of the CARLI - KNOWING what I was looking for and what I want to achieve based on previous vehicles.
Thanx again!
CCW stated: "Minimum setup for 37’s and Raptor quality ride at high speed are opposing desires."
Nothing short of an absolute "CLASSIC RESPONSE".
Clean, Clear, Concise and too the point!
Thank YOU!!!
Thanx again!
I did the same. Platinum was mighty plush, but I wanted to have $ for upgrades and to make it my own. FYI...best bang for the buck so far was the 5 Star tuner. It changed up the shift points and got rid of the pedal lag. I’m really loving the 7.3 now. Good luck on your build.
Thanx in advance.
I think if you want to get close to a Raptor ride, you’ll need to piece mill from different companies. From front to back I’d say:
-carli torsion sway bar
-icon or carli coils
-accutune shocks at your desired tune
-icon 4 link to replace radius arms
-icon or carli full progressive leaf pack
I know Carli has a big footprint in the SuperDuty space but there’s a lot more out there as good or better. Like Accutune, I firmly believe they can build a much better shock.
I’m leaning towards Icon 4.5” stage 2…maybe 3. Keeping stock wheels with 37x12.50r18 Pro Comp mt’s. But I got a while until my warranty is out. Just hit 2500 miles.
Hey everyone, not trying to hijack the thread but didn’t want to start a whole new thread and haven’t seen the answer to my questions anywhere else. I’ve been enjoying this discussion as a carli 3.5 backcountry lift is one of the first things I’m going to do. I feel after the waiting I’m going through getting this truck and the money I’m spending on it, I can handle waiting for the lift to get the best.
Anyway side question…do aftermarket parts for the 2017 and up fit the 2022s?
Yes, all 2017-2022 parts are interchangeable. The one thing to keep in mind is that Tremors have effectively the same suspension as the 2017-2019 trucks that are taller. That's why the 3.5" Carli kit for the 2020 will only give you 2.5" of lift on the Tremor.
The only real difference on 2020+ trucks comes down to not all of these trucks needing a track bar relocation bracket. Some do, but I've never been a fan of relocation brackets because they're finite and not adjustable. If budget allows, I always recommend an upgraded adjustable track bar.
Something is going on. I had mine installed before Memorial Day.
Lead times are rough on getting materials for a lot of things right now, but suspension components have been heavily impacted. King is at 40+ weeks for new shock orders. Deaver leaf springs are at the mercy of the mills and we're seeing 60-90 days on some orders.
Thanx in advance.
3.5" 2020 kit AKA 2.5" kit for stock wheels. Coming from a Gen 1 and Gen 2 Raptor and then going to our 2019 F-250, I did my best to get this truck to ride like my old Raptors. We're currently running the Icon Stage 5 2.5" kit with new front springs, front/rear shocks, dual steering stabilizer, and adjustable track bar. We will be adding the Carli Torsion bar and full replacement leaf springs to fully dial it in.
The info that @ccw added below is very accurate. I can speak that the front torsion bar and rear leaf springs make a substantial impact.
Great info here!
Small nitpick here: Carli states it's 1.5" of lift on the Tremor. :)
Measuring a stock Tremor against a standard Super duty shows the Tremor to sit approximately 1-7/8″ higher in the front. The rear has quite a bit more lean on the standard Super Duty but, if averaged, about 1″ taller in the rear.
With this in mind, our 3.5″ and 5.5″ systems on the standard Super Duty will actually be a 1.5″ and 3.5″ System on a Tremor.
Do you know if the front torsion bar will work on a Tremor that is otherwise stock? If not I'll give CJC a call.
I'm not looking to put 37's on, so will likely do a reverse level to reduce some of the rake (won't go full level) but am keeping an eye out for ways to still improve the ride.
That's interesting for sure. In my conversations with CJC, we've basically agreed that treating Tremor suspension height the same as 17-19 4x4 trucks is pretty much standard. I'll have to dig into this more.
Regarding the torsion bar, they're not intended for stock height trucks.
Thanks for the clarification on the torsion bar!
Everything I've heard is that the Tremor is roughly 2" higher than non-Tremor, and that's roughly equivalent to the 17-19 trucks as you say.
What's intriguing is that despite that apparent 2" height difference, Carli claims the 20+ lift is 3" and 17-19 is only 2.5". If there was a 2" drop between the model years, and the lift is the same, I would expect the difference in lift height to be around 2", not 0.5".
Laying it out in a table for clarity and using the 20+ non-Tremor as our baseline (only looking at front lift):
TruckKnown initial liftClaimed Carli lift amountResulting final lift
20MY non-Tremor03.5"3.5"
20MY Tremor2"1.5"3.5"
19MY2"2.5"4.5"
So ya, something funky is happening with the numbers. Perhaps the Carli parts are different between 17-19MY and 20MY+? Though I didn't think they were.
Other possibility is that the Tremor is really only a 1" factory lift in practice. That would make the numbers line up, but goes against Carli's bump stop measurements which put it at around 2" lift over a non-Tremor.
This whole Carli thing is way too confusing. Especially at those prices for only a 1.5” lift. Really?
Yes it could definitely be more clear; however, price wise you’re paying for an amazing ride, not lift height. Comparing other lifts of similar quality (e.g. Icon) they‘re in the same general price range.
The parts and manufacturing certainly isn’t cheap as-is, but a big part of that is R&D cost to figure out the custom valving for the shocks as spring rates for the springs.
If you purely want lift height, without an improvement in ride, there’s plenty of less expensive options; however, they won’t net you much of a ride improvement. According to many people they can even feel worse than stock depending on the lift.
I know and I hear you. I’ve lifted many trucks and understand the difference in quality shocks and springs. Usually when I lift a truck I’m looking to go for comfort and height for that price. not just for an 1.5” that’s all I’m saying. Now if you are looking to do a smooth ride, then yes there’s no price on comfort. And quality as well.
Now if you really wanna upgrade. Go for the coil over conversion kit and also have the other upgraded shock on there as well.
