- Feb 21, 2024
- 903
- 1,732
- USMC
- 24 F250 Platinum H.O.
- 2015 VW Jetta TDi, 2018 CVO Street Glide
Speaking of Ex’s….
Would you like to elaborate on why you dumped her!?
I honestly shouldn’t have. Had a lot of work done to her. It sat a lot and had a buddy bugging me to buy it. I agreed with the deal of, I’ll give you one hell of a deal if you let me buy it back at the same price when you want to get rid of it. Well….. you can imagine how that one turned out.Would you like to elaborate on why you dumped her!?
Was the hpop a DieselSite Adrenaline pump? I remember them being a go to back in the day.I honestly shouldn’t have. Had a lot of work done to her. It sat a lot and had a buddy bugging me to buy it. I agreed with the deal of, I’ll give you one hell of a deal if you let me buy it back at the same price when you want to get rid of it. Well….. you can imagine how that one turned out.
To name a few mods on the EX; KC turbo 68mm, ARP studs, 190/50 injectors , BPD 58v ficm, BPD water pump, BPD oil cooler, fully built transmission, FICM tune, O Dawgs custom 03 intake manifold, aftermarket HPOP (can’t recall name brand), Derrick Rose traction bars, train horn, there’s more smaller mods I done to it. That was my second 2003 Powerstroke I had. My first was a F-250 7.3L.
I believe that was it. So many years ago, hard to remember certain things.Was the hpop a DieselSite Adrenaline pump? I remember them being a go to back in the day.
Sorry you weren't able to get her back.
So you went with the DCR on a 2024? How many miles do you have on it? If you don't mind me asking, what was the total $$ all in to have it swapped out and do you think it's worth it for the piece of mind you wanted?I got this email from them also. Will be following this even though I already have the DCR installed.![]()
Honestly, I'm thinking about biting the bullet and just getting the DCR Pump installed. I've had my Truck just over 3 weeks, put 1200 miles on it and now that I'm searching the forums for maintenance tips and mods, I'm seriously having a bad case of buyer's remorse on my 2025 Tremor.
**For a Truck that stickers at $96K, you shouldn't have to do anything to it other than drive it and change the fluids and filters as regularly as your driving habits call for. Seeing all of these "Disaster Prevention Kits" and YouTube videos where Ford Denies warranty claims on failed CP4 Pumps unless you basically hire a lawyer, I find myself wishing I'd just have bought another Ram with a Cummins. I had 3 of those from 1999 - 2014 and don't ever recall doing much else than changing the oil and filters (I did replace a Lift Pump on the 99 at 115,000 miles).
There was no "Drain the water from the fuel filter every month, change the oil every three months, watch the Regen Cycles like a hawk and don't drive short trips or ever let it idle for more than two minutes", nothing. I just drove them and they never broke. At 1200 miles, I've had two Regen's run back to 0% clean and then I drove to work yesterday (30 miles round trip) and back today, (So 45 miles so far) and my DPF % is again already at 25%... All of this BS is stressing me out.
Buy a Ram with a Cummins and you can worry about cam and lifter failure, or going with the Hamilton kit and spending $7k for the preventative fix for the cam and lifter. Every one of these trucks has their flaw...pick your poison.So you went with the DCR on a 2024? How many miles do you have on it? If you don't mind me asking, what was the total $$ all in to have it swapped out and do you think it's worth it for the piece of mind you wanted?
Yes, I'd never go 15,000 or even 7,500 on an oil change. That's just more "Save the Planet" stuff to reduce the amount of used oil needing to be recycled or otherwise disposed of. I'm good with increasing the frequency of Oil Changes and even Fuel filters... My frustration is it seems like even if you do all that maintenance, you are still likely to deal with a failed CP4 and warranty denial... At the price these trucks go for, that is crazy.Welcome to the world of diesels in 2025.
Ford or not, all diesel engines operate similarly in today's world.
All diesel engines from the big three manufacturers are prone to failing fuel pumps due to different fuel quality in the U.S., as mentioned earlier.
Every diesel engine from the big three will inevitably have something to be concerned about—they have, and they always will. It's commonly known that the only component that will not vibrate off a Ram diesel is the engine. Otherwise, the issues start with transmission.
Oil changes, once performed every three months for over 50 years, are now stretched to every 15,000 miles if you use magic oil—let me know how that works out 2 years from now.
Thanks to an abundance of sensors outpacing quality control, drivers are instructed to perform certain routine maintenance checks. These checks have always existed, but perhaps many were unaware of them.
Maintenance is crucial in all vehicles, particularly in today's world, and if you want them to last a lifetime.
My uncle once remarked that he had never seen anyone spend as much time on their rig as I did, whether it was for upkeep or improvements. He drove his 2003 Cummins ten years, performing only standard oil changes, asserting it required nothing—"I drive a Cummins for a reason blah blah blah." His transmission eventually went out as he was simply pulling out of his driveway and it was all downhill from there, no pun intended. He ultimately handed it down to one of my cousins, only to discover later that he had NEVER replaced the fuel filters in 150,000 miles. The filter's paper element had deteriorated so severely inside the housing that it was truly amazing how it still ran under those conditions. I now understand why he drove a Cummins—you just drive it until it no longer goes.
You're correct there. My last Ram was 2014, loaded 2500 Cummins. Was a beautiful truck. Had major electrical issues at around 11,000 miles that the dealer couldn't fix after a week. They first said "We know your computer is fried so we ordered a new one", followed by "Engineers in Detroit disagreed on that so we are still looking, computer order was canceled", followed by "What kind of Cell Phone do you have, we think that's causing the problem"... I picked it up and traded it that night.Buy a Ram with a Cummins and you can worry about cam and lifter failure, or going with the Hamilton kit and spending $7k for the preventative fix for the cam and lifter. Every one of these trucks has their flaw...pick your poison.
Yes, I did get the DCR installed on the 2024. We had around 12,000 miles on the truck when it was done. Too me it was more than worth the peice of mind. Yes we have a warranty but personally I'd rather not have to worry about it. After the price of the DCR ($2k), I paid $2,500 to have that installed along with the Ozempic treatment & Pusher intake pipes.So you went with the DCR on a 2024? How many miles do you have on it? If you don't mind me asking, what was the total $$ all in to have it swapped out and do you think it's worth it for the piece of mind you wanted?
Thank you so much for the info!! I may follow in your footsteps if I can find a reputable mechanic here in the Tulsa area that I can trust not to mess it up. I haven't had the best of luck with that in the past when trying to find a solid mechanic.Yes, I did get the DCR installed on the 2024. We had around 12,000 miles on the truck when it was done. Too me it was more than worth the peice of mind. Yes we have a warranty but personally I'd rather not have to worry about it. After the price of the DCR ($2k), I paid $2,500 to have that installed along with the Ozempic treatment & Pusher intake pipes.
I understand we shouldn't have to spend a lot on these trucks and have to worry about certain things, but unfortunately, it's not that way. I would have loved to spent $96k on the truck, ours was $106K.![]()
