New Morimoto Fog Light kit for 20-22 Trucks
Any chance to get night shot showing the throw this put out down a dark road or such tonight?
I was going to, I'll just make a new post instead of editing my daytime pic.
Since we talked Nick I’ve been contemplating this Morimoto kit more and more. Especially with possible DD ss6 at same time.
I thought I was set on two cube but maybe I’ve thought so long I’m swaying lol. Still might just got BD kit and call it a day lol. But weighing options.
It'll be a good time to do any of them, frankly. Morimoto, DD, and BD Black Friday sales are right around the corner.
Here are the night time pics:
Just headlights:
With Foglights:
Does anyone have amber to compare to clear? Any preference to which is better?
I installed mine on Sunday. It’s an excellent kit and looks great! Only suggestion I’d offer is when you install the shroud, make sure you put bottom part below light in first then snap it in from there. I broke one of my pieces on passenger side and had to use a “plastic welder” to make a new piece. Other than that it was flawless and easy to install.
Killer!
I like the variety plus the factory look.
Are you able to run them separately?
Are you pleased with the light spread from the added fogs?
Thanks! You can run them separately but there’s another kit for wiring. It comes with the connector to plug into your fog lights which is what I used. I went with the “wide” pattern and I’m very pleased with its output. Much much better!
Killer!
You can wire them to an upfitter switch if you'd like to. There is a separate harness Morimoto sells that separates the factory fogs from the banger fogs.
Do these kits come on with OEM fogs? Or work with upfitters? Or does one light come on with OEM and then one with upfitter?
You can wire them either way. They come ready to go with wiring them with your stock fog lights to turn on at the same time. You can however purchase a wiring harness from Morimoto to have the Bangers controlled by an upfitter switch separately.
Sorry warpath. In watching the bears/eagles game I failed to articulate my real question outta joy for Bears victory. (Especially as you had answer the question I post about 10 days ago lol 🤦🏻‍♂️).
Let me articulate better now that I am focused:
We using the additional harness from Morimoto can you have one work with OEM say if I did HXB SAE Wide in the 2Banger that came on with OEM could I then do the 1 banger in something like combo or spot (undecided which?- I’m open to recs) and use their additional harness to run the 1 bangers to an upfitter?
Or am I overthinking this and should just have them all come on together and save upfitter for pillar pods and/or light bar?
