MPD piping help (SOLVED) ***
It’s been fixed! I think an updated tune on the 21’ ECU was the cure. I’ll let him update here officially when he can. I’m sure he’s catching up on a lot of work
Yes guys, that is correct.
Found the problem, a dumb one at that, then another one but at last she's rippin' and takin' names.
I'll get into all the details later tonight and hopefully we can all learn from this but what a fiasco we created by simply over looking the little stuff.
Thanks to all for the help and support - @BroncOh for always coming true.
I've been diaper free since August of '22 but now that she is totally gutless and on level 5, watch out! You will NEVER go back.
Them bi-turbo G-Wagons can now kiss my ass and eat my smoke!
This has bit me in the ass more times than I care to admit. Replacing a pinion seal when the breather line was clogged was the last straw for me 😂
Few, if any, in these forums have gone to the full MPD (MPP) piping performance kit and now I can understand why. Despite the well acclaimed and highly popular picks around these forums between the SPE or Pusher Kit, I was led on to these by my mechanic some months ago. They had been sitting on the shelf since September of '23 waiting on install (more like time).
When I decided to finally tackle this mess, I also went in on the DCR swap, because everything comes out anyway and it's only a few more nuts and bolts to get to the fuel pump at that point but back to the kit now...
This kit eliminates not only all emissions (EGR cooler and CCV filter) but also removes the throttle body valve. In doing so, you will need special calibration to avoid getting into the mess I got into (more on this later).
What you see here is full straight open pipes coming out of the manifold flanges and an open air filter, which is what rattled this entire mess.
I made it very clear to my mechanic that I DID NOT (and couldn not) run an open air filter due to my line of work and outside elements.
Well, a month later and that's the reason why you see a two tone color of the pipes -- obviously, this was NOT the intent.
I was running an S&B closed air filter box prior to this set up and my instructions were to retain the S&B filter box and land the new MDP filter, in the box location. Simple? Well, not so much. After several instructions from MPD and a few failed attempts to retrofit the MPD intake into the S&B box, my original Red Ilusion Cherry intake pipe was in several pieces and no longer in a useable state . The two were never designed to work with each other and that was the end of that story.
In an attempt to get my truck running again, I opted for a leftover pipe from a returned kit and tadda, in comes the aqua marine color. At this point, color is not a worry but rather have the truck back on the road.
She get's all bolted and back together, fire her up and guess what now? After pulling her out of the parking lot, I get a CEL so back to the drawing board we go . . .
As stated, this particular set up certain changes to the ECM. Not sure what went wrong with this constant but after a CEL, it became a variable and my brains (ECMs) were swapped around. In short, I have two brains -- the '22 PCM/ECM is on a single tune (which only emits urine use) while the '21 brain is a full new file across the board, along with new TCM calibrations, amongst others (as such is the case).
Thinking it was the '21 brain, back goes my '22 in and we get her fired up again. Hooray I thought but in the middle of swap, someone noticed something awkward; the MAP and EBP sensors were swapped (same connectors). Strange? Not to some I guess so the surgery continues to the revert procedure.
Once the '22 brain is back in the shell, truck appears to fine, no codes, DTC, CELs so I get the call to come grab her but something simply did not feel right...
After driving her, this so called increased throttle response from these performance pipes was no where to be found and my turbo was overspooling, something I had never seen before, and she was VERY loud -- of course due to the overspooling. Not liking what I saw and heard, I decided to sideline her and get her back to surgery.
In the meantime, we think something is a miss with the '21 brain so she gets some new files in hopes to solve the mysterious CEL that we got upon firing her up intially but not before we begin to wonder what's going on with the turbo and its strange behavior all of a sudden. Thinking its a VGT issue, we phone Ford and they tell us that coincidentally enough, back in January, Ford issued a service bulletin on failing VGTs and that you no longer have to purchase the entire kit to service the VGT actuator. For the price and to eliminate this hypothesis, we pull the trigger in hopes that it addresses the strange turbo behavior. Well, wrong - turbo was still acting up and everyone was scratching their head as to why, again.
That's when I came in here desperately grasping for help and/or suggestions and of course, the '22 brain was never the right brain for this set up ALL ALONG. That brain only addressed one thing and that was being DEFless. Enough with this back and forth mystery, I thought let's snap the '21 ECM and that's when magic happened, not to mention the two identical connectors from earlier in the story were in their appropriate slots and we now have a lion firing on all 8 cylinders!
That was our answer the entire time - the CEL in the beginning was simply swapped connectors as mentioned and we missed this entirely, causing us to attempt to use the '22 brain, change out a totally functional VGT, and days and days sidelines looking for answers.
She screams. She goes. She lays rubber on the ground and burns skid marks for hundreds of feet at a time. Best of all, she's totally pure and with the DCR, she rumbles! The DCR sure makes her idle very different as folks have mentioned - this 6.7 sounds more stout and simply beefier.
Having said all this, if anyone needs spare parts which are now sitting on the shelf, hollar at me and we can work out some pricing.
Not sure what a used CP4 is worth but she could be someone treasure for a bargain.
As far as the intake, I'm in the works of retrofitting the S&B box back in its place and making my original Red Illusion Cherry pipe which was welded back into one piece, work as originally intended.
I'll be sure to share that when that happens in the short future.
Yea...I see what happened now.
Yea, I'm in heavy civil road construction here in GA with good ole red clay clouds, I can't imagine you where you are running an open box... My filter looks nasty as fuck inside my S&B and AND I run a filter sock. Hell the other month I was trouble shooting my own CEL with Heavy and I think I'm fairly certain the "EGR" code I was getting was simply due to the airfilter being to fkg dirty. Oh well, I tossed in a map sensor since there was age on the truck and was worried about the soot build up you read about, that didnt fix it but I did notice the boost gauge was much more responsive (so clearly it did have soot in it), so I tossed in a new MAF sensor, while I did that I pulled my filter (dry cottom), cleaned it (compressed air from the inside) and the sock (fucking gross, used dawn powerwash in the shower), threw it all back together and it is right as rain. Truck does not like having the maf sensor without running IDS to reset learned values and you can't do it in ForScan, it will adapt but it will drive a little wonky at first under weird conditions.
It's funny you say that; just last week as I grabbing my rig from the shop, a 6.0 pulled up with an AC issue. Out comes the gentleman from the truck and is quick to mention that he works at a local mine (about two hours away) and only had that day off to address the issue before heading back into the pit (our mines in Arizona are open pit). He popped open his hood, the first thing I natrually look at when an engine is bare is the air filter. Heavens I thought to myself! I could bet all my money on the fact that the air filter was older than me the last time it was changed! It was CAKED in deposits and elements from being in that environment. I had never seen anything like it and like I said, the air filter is the first thing I naturally look when an engine hood is opened. Poor thing! It is gasping for air. It hurt to see that.
Heck of a deal you went through but all that matters is...
Super happy for you, sir. 🍻
Well -- after a fun filled weekend with projects and easter, I can say she's finally done!
It is safe to say I am super pleased about the outcome and even though the retrofitted intake pipe is not powdercoated; the Rustoleum canned spray paint was almost an identical match to the red illusion cherry. I am not the least concerned about the color but the function and getting that filter in the box was my ultimate goal and objective.
I don't want to comment much on my shop who's done most of the building (I handle the smaller stuff) but I was a little shocked they were caught with a "deer in the headlights" look with this task.
I was also shocked the engine noise didn't become at all quiter by sticking the filter in a closed box - those straight pipes surely want to suck in air and feed as much as possible.
You're welcome my friend! I'm glad I could help. Let me know if you need anything in regards to how she needs to spread that tube 🤪.
Hey AZ, I'm getting real close to doing the same to my rig. I might look you up when the time comes. Now that your shop has gone thru the growing pains.
Do hit me up - it is not hard even for the novice; it's having your mind straight and knowing what you need to know.
Very important - you must have the proper programming prior to going to this full piping kit.
You eliminate a lot and you must compensate certain parameters.
